I'm just curious--I've got a '13 F250 w/ 17" wheels. Apart from cosmetics, is there any benefit to swapping over to 18" wheels/tires? Load capacity, mileage, tread life, etc.?
I suspect a resounding "nope" but have wondered for awhile...
Can be load rating differences, but for an F250 you wouldn't need the higher rating.
I have kept the 17" wheels on my truck but went up to a bigger tire, 285/70/17 over the original 245/75/17, fills the wheel opening better and gives better ride and handling.
I don't think you'll find any difference Icthus - my '08 F250 came with 18" Factory wheels/tires when I bought it new and the first week I had it, I had it fitted with a set of 17" X 8" Helo wheels and 35X12.5R17 Toyo tires. I went down to 17s because 1.) I like the tall sidewall look and 2.) the more sidewall you have, the better the tire squats when you air it down. I Beach Camp and have to air down to carry my slide-in camper onto the soft beach sand. My new 2015 F350 has Factory 18's and I'm staying stock so either way, it works on the beach. On the road - I saw absolutely no difference. Let's see what others say... I'm definitely no expert.
Originally Posted by Ltngdrvr
Can be load rating differences, but for an F250 you wouldn't need the higher rating. I have kept the 17" wheels on my truck but went up to a bigger tire, 285/70/17 over the original 245/75/17, fills the wheel opening better and gives better ride and handling.
"LtngDrvr" has another point I forgot about - the more sidewall you have, the softer the ride!
There should be no substantive difference between 17" and 18" wheels on your F-250. Only one inch difference in wheel diameter would likely be very difficult to notice from a handling perspective on a truck like yours. Going to 18" wheels gives you a few different tire size choices, most notably from my research the availability of a 285/75/18 in a few select tires for a 35" tall tire on the stock wheels with stock suspension. So it really comes down to cosmetics and available tire sizes and tread patterns.
