What to do for rear suspension?
Old 01-03-2015, 10:37 PM
carbs & chrome's Avatar
carbs & chrome
carbs & chrome is offline
My spring mounts are moved all the way up on the frame and the 1st and 3rd springs are removed.
Before:
After:
You could get more by flipping the axle.
Old 01-04-2015, 09:53 AM
48 Steel's Avatar
48 Steel
48 Steel is offline
Not trying to muddy the waters but you can install an IFS and IRS for under $1,000.00. I did a Jag IFS and Mark VIII IRS. Check my gallery or my Built thread.
____________________________
48 Ford F1 - Darkside
46 Ford Tudor - Street Rod
"Happiness- 3 pedals and a 5 speed"
Old 01-04-2015, 10:24 AM
yamagrant's Avatar
yamagrant
yamagrant is offline
I like the stance C&C.
Old 01-04-2015, 11:34 AM
filthy6's Avatar
filthy6
filthy6 is offline
Before:
After:
What did you do for the front? I'm not trying to steel the thread. Don't know how you can change one without changing the other.
Old 01-04-2015, 12:06 PM
carbs & chrome
Hey, thanks!
Old 01-04-2015, 12:07 PM
carbs & chrome
Dropped axle and 1st and 3rd springs removed also.
Old 01-04-2015, 03:46 PM
djt14's Avatar
djt14
djt14 is offline
Really like that stance, I'm thinking I'm going to do that. Do you have any pics of the rear susp. without the box on by chance? I'm assuming that since you dropped some springs the ride is somewhat smoother? I just feel it's really stiff as is.
Thanks for the input guys!
Old 01-04-2015, 04:48 PM
carbs & chrome
Did it with the bed still on. It does ride a little smoother - even though I still need swap out the stock length shocks. Only other cost was buying hardware to secure the spring mounts. The bottom hole in the frame was the original:
Here you can see how much travel I still have. If you flip the axle you's want to notch the frame probably:
Oxfordrider
11-12-2012 06:07 PM
gpp
2004 - 2008 F150
04-07-2009 07:06 PM
daves54
02-03-2009 05:19 PM
nate5812
11-04-2004 11:20 AM
53effie
05-07-2004 08:55 PM
Quick Reply: What to do for rear suspension?
