need help on 1999 4.0sohc vin code E
Old Jan 1, 2015 | 08:05 PM
isaachorrom's Avatar
isaachorrom
Just bought a 1999 ford explorer limited , with a 4.0 sohc vin code E , for $400 pretty sure it has a blown headgasket
How do u remove heads on this vehicle , do u need speacial cam tools like I read
Old Jan 1, 2015 | 09:36 PM
m-chan68's Avatar
m-chan68
The tools you will need to time this engine are in this link below:
OTC Tools & Equipment 6488 Ford Sohc 4.0L V6 Cam Service Set
If you have anything else physically in your possession other than those tools, there is no point in trying to disassemble that engine because it will never run. This engine uses no timing marks, nor are any of the chain sprockets keyed. They are fastened together entirely with bolt torque.
It may end up less expensive for you just to purchase a used, running complete engine to install in its place.
Old Jan 3, 2015 | 11:43 PM
Mikeman's Avatar
Mikeman
To get the SOHC heads off, don't you have to remove the engine anyway?
Old Jan 4, 2015 | 01:17 PM
m-chan68's Avatar
m-chan68
My point exactly.
isaachorrom
Jan 1, 2015 06:05 PM
msquared100
Nov 8, 2009 07:18 AM
pjlandry
Dec 17, 2006 11:36 PM
