'76 F100
Old Jul 20, 2003 | 01:51 PM
Stanstruck's Avatar
Stanstruck
'76 F100
Hi. I'm looking at buying a '76 F100. It has the 360 and not alot of rust. Would this truck have any problems towing a small (2000-3000 #) car?
It has an auto. Would this be the C6?
$300....
thanks,
Stan
Old Jul 20, 2003 | 05:02 PM
76supercab2's Avatar
76supercab2
'76 F100
The odds are very good that the trans is a C6.
How are you going to tow the car? On a trailer or a dolly. If on a trailer get the combined weight of the trailer and car. The trucks weight will be around 5500-6000 lbs. The towing rating will be approx 9000 - 10K lbs. So if you have a light trailer and are on level ground most of the time it will probably do fine.
I towed a 72 mustang and the combined weight was around 5000lbs with my F-150. I was at the upper limit of what the truck would do but it did it. I took my time and kept things under control and made it 300 miles with no problems. (Had problems with U-Haul but that's another story).
Sounds like a good deal and for occasional towing should work. If you're going to tow often you may want to look for a 250 or 350. Bigger brakes, radiator etc.
Old Jul 20, 2003 | 08:26 PM
Stanstruck's Avatar
Stanstruck
'76 F100
Thanks.
It's not exactly what I was looking for (F150, F250 4X4), but at that price, it's kind of hard to pass up.
I used to have a '72 Mach I. Those things are heavy!
thanks again,
Stan
SStans
Testing.....
Jun 30, 2014 10:59 AM
FordManStan
Jun 11, 2005 02:18 AM
Stanstruck
Ohio Chapter
Feb 2, 2005 09:57 AM
Stanstruck
Ohio Chapter
Oct 5, 2004 03:40 PM
anticrust
May 21, 2003 12:24 AM
