Soon to be driver
Old Dec 31, 2014 | 11:01 PM
jiminn's Avatar
jiminn
Soon to be driver
Upgrades by jiminn | Ford-Trucks
Old Dec 31, 2014 | 11:05 PM
Tedster9's Avatar
Tedster9
Fine lookin' machine!
Old Jan 1, 2015 | 01:55 PM
theodore/teddy's Avatar
theodore/teddy
Refyred
Happy New Year/Truck! Now drive the wheels off that truck.
Old Jan 4, 2015 | 08:26 AM
Choptopjimmy's Avatar
Choptopjimmy
What is the front bumper off of? It looks way too wide for the truck. Jim
Old Jan 4, 2015 | 06:21 PM
jiminn's Avatar
jiminn
Driver
I think the front Bumper is off a 62 F100, thats what the PO said. I am looking for an original 57-60 painted bumper.
Old Jan 5, 2015 | 12:12 PM
Jason428's Avatar
Jason428
I was wondering where that truck went. seen it on craigs, sounded like a good deal.
Old Jan 17, 2015 | 04:07 PM
jiminn's Avatar
jiminn
Driving
Finally got to take her on the first test drive, WOW what a Machine. After I put the fire out under the dash and rewired the heater. She's a handful rolling down the road. I think I need to look at the slop in the steering, hopefully there is an adjustment to take the play out.Have to run at 1/2 choke to get any power. So I will be looking into a rebuild kit for the carb. And info on the steering issue.
Old Jan 17, 2015 | 06:37 PM
spurredon's Avatar
spurredon
Glad you got to go for a spin. That is always fun. The play in the steering is more than likely a compounding of many things unless you have checked them out. Tie rod ends and drag link as well as wear in the steering box can create a lot of movement in the steering wheel before the wheels actual feel it. There is a preload adjustment for the worm bearing in the gearbox but you need to follow the procedure outlined in the shop manual or you could end up causing more wear.
Old Jan 17, 2015 | 06:50 PM
jiminn's Avatar
jiminn
I will look it up. thanks.
Old Jan 17, 2015 | 08:13 PM
hiball3985's Avatar
hiball3985
Another major problem in the steering gear box is the two bushings that the sector shaft ride on, most people over look that.
Old Jan 18, 2015 | 06:57 AM
spurredon's Avatar
spurredon
That's true, I ended up changing those in the one I'm using. I think I just matched something up at NAPA but it has been awhile.
Old Jan 23, 2015 | 07:33 AM
jiminn's Avatar
jiminn
New Plate
Got my License Plate, Still need correct bumper would like a painted original.
I seen on another post they put 59 grilles on 60 Bigger trucks , Wonder if this carried through on some F100's
Just noticed the DMV messed up and put a O (Oh) after 6 instead of a 0 (zero) My Buddy say 6 of 100?
Old Jan 24, 2015 | 10:30 PM
jiminn's Avatar
jiminn
rebuild holley issues
So I rebuilt my 1904 Holley with the Mikes Carb kit. Pretty straight forward.
Star it up runs nice idles then the gas starts puking out the over flow. Pull cover pull gas like spray cleaner in the seat area. re assemble same thing. Spent time trouble shooting everything I could find online. Need some feed back. I will try to figure out how to check fuel pressure tomorrow.
Old Jan 25, 2015 | 08:05 AM
hiball3985's Avatar
hiball3985
Are you sure you put the gasket between the seat assembly and the body?
Float level adjusted?
Is the float good?
Old Jan 25, 2015 | 08:18 AM
jiminn's Avatar
jiminn
Yes I have the gasket between the seat and body, I see on the video from mikes carb where I got the kit he says he likes to loosen and tighten the screw a few times to seat the copper. I adjusted the float level , The Brass Float is in god shape no holes , no gas inside. I verified it was not rubbing on cover. I think I need to figure out how to check my fuel pressure.
