a/c
Old Jul 20, 2003 | 01:10 PM
vics97xlt's Avatar
vics97xlt
Angry a/c
my daughter has a 2002 explorer in which the a/c all of a sudden stop working. i checked the fuses for the a/c clutch in both fuse boxes. both were fine. switched the relays. that also checked out. also checked out the diode which was ok. could it be the switch in the dash? also checked the clutch to see if it was free. it was. any help out there would be appreciated. thanks in advance
Old Jul 20, 2003 | 01:33 PM
Bob Ayers's Avatar
Bob Ayers
a/c
First, welcome to FTE!!!
Check the charge level in the system. If it below a certain level,
then the clutch on the compressor will not engauge.
Old Jul 24, 2003 | 04:50 PM
vics97xlt's Avatar
vics97xlt
a/c
cheked the charge level its ok
made appointment at dealer.
thanks
Old Jul 27, 2003 | 09:24 AM
HomerWinzlow's Avatar
HomerWinzlow
a/c
If it has a 4.0 OHC they have a lot of problems with thier engine thermostats. If the engine overheats then the processor will cut off the A/C. It will work fine till the engine gets up to the hot point.
Old Jul 30, 2003 | 09:33 PM
vics97xlt's Avatar
vics97xlt
a/c
dealer can't seem to find the problem. they say it is electrical somewhere. have to keep the vehicle overnight.
let you know what happens.
Old Aug 5, 2003 | 12:06 PM
vics97xlt's Avatar
vics97xlt
a/c
well, after all the troubleshooting at the dealer the problem was with the connection of the cd changer that was installed aftermarket. the connection was loose on the power side of the connection. back in business. thanks everyone.
RA5226
May 21, 2014 10:41 PM
hotrodhippi
Dec 6, 2013 02:46 PM
Pmbarrett
Jun 29, 2011 08:54 AM
cherrob123
Sep 11, 2010 01:57 PM
TimmyAbrams
Sep 6, 2007 04:54 AM
