Tire Cracking
Old Dec 30, 2014 | 08:31 PM
49fordv8f4's Avatar
49fordv8f4
Tire Cracking
I didn't want to hijack Joe's thread where he was asking about the tire cracking on his F4. There is some good info there as usual, I learned how to read the date code on my tires.
Is there anything you can coat a tire with that will slow down the ageing? Do any of the tire sprays used do that? I am assuming that a tire cracks as it ages because the oils used in the manufacture of the rubber compounds in the tire, leave, evaporate, or dry out as the tire ages. If that is the case, it seems to me that wetting the outside of the tire periodically the right chemical might slow the ageing/cracking down. Any thoughts?
Mark
Old Dec 30, 2014 | 09:24 PM
Harrier's Avatar
Harrier
That's a good question. I wonder if something like Ru-Glyde. I did a quick search and someone mentioned Vaseline, but another said that might not be good.
Keep your truck in a garage out of the sun will help too, but I'm sure you know that.
Let's see what our resident experts have to say. My tires will rot out before the tread wears out. If I can prolong their life with something, that would be great.
Old Dec 30, 2014 | 09:27 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Finding NOS and good used bias ply traction tires is one of my obsessions because my sizes aren't repop'd. Josh and Mark do the same, and I swap emails with Napco guys that look for them too. I think it's primarily UV exposure that degrades the rubber. I've found full and partial sets that I'm sure are 20+ years old yet show no signs of cracking. Most were generally in warehouses with little outside light, and I have used 19.5s on the chassis now that came from a rural fire truck that spent most of its time indoors. For a limited use or show truck I think they are fine. Stu
Edit - Also, I have a buddy that does detailing professionally. He's told me that products like Armor All are bad for rubber. He suggested soap and water. And I'll say tire covers like the motor home folks use. Stu
Old Dec 30, 2014 | 09:29 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Well, when I first got the "new" tires on my truck (the replacement widow maker wheels and tires) I had the truck in my driveway and protected the tires with RV tire covers.
Since I've been driving it, I have had the truck garaged, so no sun damage.
I think my cracks got worse from driving on potholed streets because of their age.
Old Dec 30, 2014 | 09:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Nothing made of petroleum is good for tires (as a treatment). Ozone is another tire-killer. Tire cleaners and "shines" are bad for them.
Old Dec 30, 2014 | 09:39 PM
pineconeford's Avatar
pineconeford
Knuckle Bandage Sales Rep
I wonder if beeswax would do the trick.
Natural ingredients, and will have some shine too.
If so, I gotta tell my bees to bump up production - we have a new market to corner.
Old Dec 30, 2014 | 10:26 PM
GB SISSON's Avatar
GB SISSON
Not necessarily proud of it but back in the day because of my obsession with one tons and 7.50 x 17s, I have had really good luck filling surface checks in junkyard tire sidewalls with a marine sealant called 'sikaflex'. It is for boat seams and is an adhesive too. It comes in black and dulls out as it dries. I force it in with a putty knife and wipe excess with laquer thinner. When it dries, there is no more crack. I always feel the cord is intact, it is many layers thick and the sun doesn't get in there. Maybe I have just been lucky, but I use them as real trucks and have never had a tire fail unless I ran through the place where we de-nail boards for our reclaimed wood business....And that can happen to a new 'store-bought' tire...
Old Dec 31, 2014 | 05:53 AM
Harrier's Avatar
Harrier
Well they retread tires all the time. (And the come flying off down the road....) I wonder what process they use to do a retread? Could a home process similar to what you mentioned be possible? If a tire is low use, I would think something could be done fairly safely.
Now if you are going 70 mph anywhere, you need new tires. But 40 around town??
Old Dec 31, 2014 | 06:32 AM
truckdog62563
Agree. I had four traction retread bias 19.5s that I sent to a Napco guy a couple weeks ago. No idea how old the casings were, nor the new treads, but they looked great. He's mounted them up, and will use them on both front and rear axles which would make me uncomfortable. He's tickled to have them. Again, as said, it'll be a limited use, low speed, ride. Stu
Old Dec 31, 2014 | 09:17 AM
fladoodle's Avatar
fladoodle
I wouldn't think someone could or should attempt a retread in their own garage or shop. I've seen the process done and it requires lots of heat and specialized equipment to make sure the new tread is totally attached and even. I barely trust retreaded tires from a reputable shop, let alone in some guy doing it in their garage. I doubt you could ever even get them to balance right!
Old Dec 31, 2014 | 12:01 PM
CharlieLed's Avatar
CharlieLed
I have no experience with this product but it seems like there are products such as these that are made to preserve tires and stop cracking...Age-Master No.1® Official Site - Rubber Protection - Rubber Protectant - Protection for Rubber - Chem Pro Inc.
Old Dec 31, 2014 | 02:16 PM
raytasch's Avatar
raytasch
Believe Nothing
My understanding is that tires deteriorate from non use as well as being exposed to the elements and ozone. By using and flexing them the ingredients of the rubber compound will work their way to the outside of the tire and help prevent cracking.
Old Dec 31, 2014 | 05:14 PM
69 f-100 aman's Avatar
69 f-100 aman
I went into a tire shop the other day to get some tires mounted and they had a sign hanging inside the shop that said they would not mount any tire that was 5 years old or older marked by the DOT date on the tire.....
Old Dec 31, 2014 | 06:32 PM
49fordv8f4's Avatar
49fordv8f4
Thanks for all the replies. I don't have any experience with the tire sprays that you see a lot of people use at car shows. It sounds like they may not be the best thing for tires, unless you like the wet tire look. I may check out the coating that CharlieLed mentioned in his reply.
Thanks again, Mark
Old Jan 1, 2015 | 01:16 AM
abe's Avatar
abe
Interesting dilemma. If you don't use them they dry rot and crack. If you use them so they don't crack you wear the tread...
