SPEED CONTROL PROBLEM
Old Dec 30, 2014 | 03:31 PM
MarauderV8's Avatar
MarauderV8
Since a few days my crusie control is w/o function.
I am very to grow desperate. Thats what i tried:
                Anybody has an idea, what can it be? It is very, very important for me.
                Thank you for help
                Old Dec 30, 2014 | 05:12 PM
                alloro's Avatar
                alloro
                Does the speedometer work correctly?
                Old Dec 31, 2014 | 04:53 PM
                MarauderV8's Avatar
                MarauderV8
                Yes, it work correctly
                Old Dec 31, 2014 | 10:02 PM
                alloro's Avatar
                alloro
                In that case it sounds like a mechanical issue with the actuator controlling the throttle.
                Old Jan 1, 2015 | 10:52 AM
                MarauderV8's Avatar
                MarauderV8
                but there is nothing that blocked the cable or anything
                Old Jan 1, 2015 | 11:39 AM
                alloro's Avatar
                alloro
                Could be the actuator itself has failed and does not move the cable.
                Old Jan 1, 2015 | 02:51 PM
                MarauderV8's Avatar
                MarauderV8
                Have an idea, the night before I realized, that it not work, I notice that i can move the shifter w/o press the brake. I noticed it after I can't move the shifter. In the wiring diagram I found an additional switch, the brake shift interlock. Tomorrow I will check it....
                Old Jan 2, 2015 | 03:33 AM
                alloro's Avatar
                alloro
                How can that be since in your first post you said, "checked the switch at brake pedestal --- passed"?
                Old Jan 2, 2015 | 11:17 AM
                MarauderV8's Avatar
                MarauderV8
                yes, checked again today. Stop lamps are working proper, two wires are hot at all time, the others are hot after pressing the pedal
                Old Jan 2, 2015 | 11:23 AM
                alloro's Avatar
                alloro
                I want to take a look at the wiring diagram, what is the year make and model?
                Old Jan 2, 2015 | 02:59 PM
                MarauderV8's Avatar
                MarauderV8
                Thank you in advance, Navigator from 2004
                Old Jan 2, 2015 | 03:07 PM
                MarauderV8's Avatar
                MarauderV8
                Btw, during my problems with the speed control I found a disconnected plug under the dash. The plug is grey and has four wires, black, green, yellow and blue. Found out, that is for the steering wheel position, but can't find the sensor. Do u know, for what is that? Is it an optional unit?
                Old Jan 3, 2015 | 10:15 AM
                MarauderV8's Avatar
                MarauderV8
                okay, it´s for the steering sensor, it isn´t mounted at mine. Seems to be an option.
                but i found news, i don´t know since when, but my Auto Lock doesn´t work although it is activated. And the Auto Lock system is dependent from the vehicle speed. May this can help to find a solution.
                I checked very everything again, can´t found any faults.
                Old Jan 3, 2015 | 02:40 PM
                alloro's Avatar
                alloro
                2WD or 4WD?
                Old Jan 3, 2015 | 02:58 PM
                MarauderV8's Avatar
                MarauderV8
                4WD. Thank u for trying to help me
