Radio/power window problem
Old Dec 30, 2014 | 09:21 AM
Jacobar91's Avatar
Jacobar91
I have a '95 f350 single cab,
I recently tried to install a pioneer head unit into the truck, wires everything up all worked well. When I hit the door lock as well as power window switch the radio goes into protect mode. Any ideas?
Thanks
Old Dec 30, 2014 | 10:31 AM
glovemeister's Avatar
glovemeister
Did you use a radio harness adapter?
Old Dec 30, 2014 | 11:52 AM
Jacobar91's Avatar
Jacobar91
I used the adaptor for the truck. I'm going to buy another just to be sure, but I am stumped. Why would the locks and windows tie into this at all?
Old Dec 30, 2014 | 02:34 PM
ProjectDually's Avatar
ProjectDually
I'm not sure, but do the radio and door functions all on the same/similar fuse? If not, how did you wire the connections? Did you solder them or use a crimp connection? It would appear there is a relay shared between the power windows and radio. I read about this somewhere else.. IIRC, Ford is notorious for this in most of it's vehicles.
DogRidesInBack
Jul 31, 2018 08:46 AM
JennMcGraw
Jul 22, 2018 08:43 PM
Wh1t3Xpo
15
Sep 11, 2010 12:57 PM
firemanpat29
Nov 20, 2009 07:01 PM
