Moisture problems in engine
Old Dec 29, 2014 | 07:03 PM
JRitt's Avatar
JRitt
I have an F-100 with the 300 straight 6 engine. When I pull the dip stick it shows sign of moisture. A little bit of the oil is milky/grey but most of the oil on the dip stick looks fine. I have also noticed some moisture under the breather/oil cap on the valve cover. When I first notice this I did an oil change thinking the head was cracked and antifreeze was the issue but all of the oil looked fine when I drained it. Sooo I'm confused and want to correct the problem so I don't damage the engine!
Can anyone help!!!
Old Dec 29, 2014 | 07:10 PM
JWC 3's Avatar
JWC 3
Does your engine get up to the proper temp ?
Old Dec 29, 2014 | 07:21 PM
JRitt's Avatar
JRitt
Yes it seems to. I havent put a thermometer in the radiator to see how hot it gets
Old Dec 29, 2014 | 07:33 PM
circletrack47's Avatar
circletrack47
I've had this problem in my race engines when I don't have my shop stay warm over night then heat it up while I'm working. Condensation forms, since it has a breather I've found the moisture forms in the valve covers and that could be what it is.
Old Dec 29, 2014 | 07:40 PM
JWC 3's Avatar
JWC 3
My 53 tends to form condensation more in colder weather . Especially with short trips and infrequent use .
Old Dec 29, 2014 | 07:45 PM
raytasch's Avatar
raytasch
Believe Nothing
That is common to see, especially this time of year in cold climates and short trips. Make sure the truck has a working thermostat and drive the truck an hour or so to boil the moisture out of the engine. You may have to partially cover the radiator to get the engine to temperature.
Monte1go
Dec 21, 2013 07:39 AM
IsoGrifo
Dec 9, 2009 06:16 AM
gatruckman
Jan 10, 2009 10:48 PM
5.4L to Freedom
Dec 15, 2008 09:17 AM
JoeCool223
Aug 22, 2006 03:06 PM
