Radio install 95 F250 different colors then diagrams
Old 12-29-2014, 12:52 PM
73richards250's Avatar
73richards250
73richards250 is offline
So I have a pioneer radio im trying to install in my 95 f250. My problem is I have a wiring adapter for the pioneer, but it only has 11 wires ( one of which is a remote wire) and my stock system has 15 wires, 8 on the left connector, 7 on the right. My second problem is every wiring diagram i can find does not match the actual colors of wires I have under the dash. This is a list of the colors I have in the order they appear.
LEFT CONNECTOR(from bottom to top):
pink/brown
pink/blue
green/orange
white/green
tan/yellow
pink/green
blue/white
orange/green
RIGHT CONNECTOR(from bottom to top):
green/black
green/black
orange/black
blue/red
yellow/black
black
green/purple
If anyone has this same problem please HELP!!!
Old 12-29-2014, 01:13 PM
rutherk1's Avatar
rutherk1
rutherk1 is offline
Do you have a harness? There is an ISO standard for those colors but OEMs don't abide by them.
Unless I am missing something about what you are trying to do, get one of these.
Metra/Scosche are 2 brands.
Match up the colors on the pioneer harness to the new harness and plug it in. I have done many of the early to late fords and I always used a harness.
You can get them for a few bucks online or best buy for 15 or so dollars.
One harness is for the speakers and the other is for power/ground/constant. Stuff like that.
Good luck. I hope this helped. You certainly can splice into your truck wiring but this is just another idea that may help.
Old 12-29-2014, 01:19 PM
73richards250
Hey thanks for the reply. What Im trying to do is splice the stock wires into the pioneer connector I have with the radio. The speaker wires I have figured out, but what im really stuck on is the ground wires.
This is the best description of what I have and actually I just found it.
The two GREEN/BLACK ground wires make no sense to me because there is already a black ground wire. Can you tell me if I should just leave the two grn/blk wires disconnected and just connect the black ground?
Old 12-29-2014, 01:39 PM
rutherk1's Avatar
rutherk1
rutherk1 is offline
As long as the pioneer harness black is going to chassis, you should be good.
Since I have always used a harness, I have never noticed the multiple green/blacks. If your main concern is the ground wire, you could just put a 0 ring connector on the black pioneer wire and secure it under a bolt to the chassis somewhere. That would certainly work.
You really only need 2 wires from that seconds harness. 12 volt, and ignition (which I think you figured out). The ground can go under a metal bolt that is bolted to something metal.
EDIT: Just looked at the diagram. all 3 of those (black and the black and greens) go to a ground. Just grounded to different locations. Probably just to support different factory configurations.
You could always probe with a multi-meter to be sure but any of those should work.
Good luck!
Davetruck
06-21-2015 04:18 AM
ghunter1234
1999 to 2016 Super Duty
02-05-2015 09:34 PM
dennisspeaks
12-16-2011 08:39 PM
78f150custom
1983 - 2012 Ranger & B-Series
06-27-2004 09:33 PM
Walking_Tall_0403
Aerostar
10-27-2003 01:05 AM
Quick Reply: Radio install 95 F250 different colors then diagrams
