Hi,
Decided to upgrade my radio, discovered previous owner hacked up the wires pretty good, no chance of using a harness adaptor. I've got most of the wires ID'd except two. Help?
The source I used said the ground wire is Black/Green not solid black. Is that true?
The two I don't know are the left-most: solid black, and red/black
Thanks...
You didn't say what year your truck is but they didn't change much year to year.
2008 Ford F250 Stereo Wire Harness Color Codes
Car Radio Battery Constant 12v+ Wire: White/Red
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Black/Blue
Car Radio Illumination Wire: Violet/Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Violet/Red
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
