Radio install 95 F250 different colors then diagrams
So I have a pioneer radio im trying to install in my 95 f250. My problem is I have a wiring adapter for the pioneer, but it only has 11 wires ( one of which is a remote wire) and my stock system has 15 wires, 8 on the left connector, 7 on the right. My second problem is every wiring diagram i can find does not match the actual colors of wires I have under the dash. This is a list of the colors I have in the order they appear.
LEFT CONNECTOR(from bottom to top): pink/brown pink/blue green/orange white/green tan/yellow pink/green blue/white orange/green https://cimg2.ibsrv.net/gimg/www.for...5f1abd7083.jpg RIGHT CONNECTOR(from bottom to top): green/black green/black orange/black blue/red yellow/black black green/purple https://cimg3.ibsrv.net/gimg/www.for...4bc6b80794.jpg If anyone has this same problem please HELP!!! |
Do you have a harness? There is an ISO standard for those colors but OEMs don't abide by them.
Unless I am missing something about what you are trying to do, get one of these. http://ecx.images-amazon.com/images/I/21Cf4wUs8qL.jpg Metra/Scosche are 2 brands. Match up the colors on the pioneer harness to the new harness and plug it in. I have done many of the early to late fords and I always used a harness. You can get them for a few bucks online or best buy for 15 or so dollars. One harness is for the speakers and the other is for power/ground/constant. Stuff like that. Good luck. I hope this helped. You certainly can splice into your truck wiring but this is just another idea that may help. |
Hey thanks for the reply. What Im trying to do is splice the stock wires into the pioneer connector I have with the radio. The speaker wires I have figured out, but what im really stuck on is the ground wires.
This is the best description of what I have and actually I just found it. https://cimg8.ibsrv.net/gimg/www.for...fd5eb2d144.jpg The two GREEN/BLACK ground wires make no sense to me because there is already a black ground wire. Can you tell me if I should just leave the two grn/blk wires disconnected and just connect the black ground? |
As long as the pioneer harness black is going to chassis, you should be good.
Since I have always used a harness, I have never noticed the multiple green/blacks. If your main concern is the ground wire, you could just put a 0 ring connector on the black pioneer wire and secure it under a bolt to the chassis somewhere. That would certainly work. You really only need 2 wires from that seconds harness. 12 volt, and ignition (which I think you figured out). The ground can go under a metal bolt that is bolted to something metal. EDIT: Just looked at the diagram. all 3 of those (black and the black and greens) go to a ground. Just grounded to different locations. Probably just to support different factory configurations. You could always probe with a multi-meter to be sure but any of those should work. Good luck! |
