6.7 Code Reading
Old Jan 10, 2015 | 05:46 PM
senix's Avatar
senix
nox sensor would be emissions warranty. Are you past that?
sdetweil's Avatar
sdetweil
Originally Posted by mtnxtreme800
I figured they reset it, but if it was bad wouldn't it throw the same code again. And I still have warranty but they said its not covered ??? First they tell me anything diesel related is covered, but this sensor is not covered, is it not diesel related ??
Intermittent. I'm still on 3/36.
Old Jan 10, 2015 | 05:51 PM
m-chan68's Avatar
m-chan68
Did they run the base part number (9D378) to confirm it isn't covered?
Old Jan 10, 2015 | 05:56 PM
mtnxtreme800's Avatar
mtnxtreme800
I have 80k miles my warranty ends at 100k. Mike I don't know if they ran the base part number are you saying it was an update, recall type thing they were changing for free ??
Old Jan 10, 2015 | 06:50 PM
sdetweil's Avatar
sdetweil
What warranty? Diesel, drivetrain? Some extended warranty?
Unless u have extended the emissions ends at 50 or 60k miles
Old Jan 10, 2015 | 07:21 PM
m-chan68's Avatar
m-chan68
Okay, so you've expired on mileage. There were a few of the earlier model years that would randomly sent NOx sensor performance codes. As a result, they were updated somehow (don't ask me how), which resulted in a changed up part number to go along with and updated PCM calibration. And no this wasn't a recall.
Old Jan 10, 2015 | 08:01 PM
mtnxtreme800
They told me I am covered for anything "diesel related " till 100k. So if the CEL doesnt come back on should I still change the NOX ?
Old Jan 10, 2015 | 08:26 PM
sdetweil's Avatar
sdetweil
I think that is the core engine only.
I would plan on changing it. Give you some time to find parts.
You might also want to find a code reader/reset tool. Then you don't have to pay 110 again.
Old Jan 10, 2015 | 08:55 PM
mtnxtreme800
ok my scan gauge 2 read codes and reset on y 6.0 am in the process of setting up for the 6.7
Old Jan 10, 2015 | 09:01 PM
m-chan68's Avatar
m-chan68
Just because the "Check Engine" light doesn't come back on, doesn't mean there isn't a DTC set. For what it's worth, the particular truck I had a similar issue with, was resetting that particular DTC after a few miles of driving it, after it was cleared before the DTC would come back (but the "Check Engine" light didn't come back on right away). As far as whether to change out the sensor or not, I would just for peace of mind. Be glad that your truck is a '12 model year with only one NOx module and one NOx sensor. The '13 to current model years now have two (NOx sensors and NOx modules).
Old Jan 11, 2015 | 07:18 AM
mtnxtreme800
thanks mike, I'll swap it out and should I look for the updated part number you posted, also how are the 12's with the egt sensor issue, should I keep a wrench and spare sensor in the truck with my scanner ?
And just to throw a wrench in the works, what is involved in removing that section of pipe and doing away with the NOX and EGT sensors ? Is it very expensive, do I have to get rid of EGR too, need special tuner etc. etc. ?
Old Jan 11, 2015 | 07:24 AM
sdetweil's Avatar
sdetweil
I carry a couple of EGT sensors and the NOX sensor in my truck, with tools.
getting a delete pipe isn't too bad, couple hundred dollars..
but you must have a tuner to tell the computer that the sensors are 'good',
and to turn off the failsafe regen (will regen about 600 miles if it thinks the sensors are lying)..
tuner + delete pipe is ~ $1300-$2000
on ebay search ford 6.7 delete.. there are of course other places to get things.
egr delete is additional, optional.
Old Jan 11, 2015 | 07:32 AM
  #28
mtnxtreme800
Thanks Sam shed a lot of light on it, got some thinking to do .
Old Jan 24, 2015 | 06:56 AM
  #29
mtnxtreme800
Ok swapping out my NOX sensor this morning, can I reset the CEL by disconnecting batteries, and if so do I have to disconnect all the terminals or just the ground etc. ? I havent had time to set up my scan tool yet to reset !
Old Jan 24, 2015 | 06:58 AM
  #30
senix's Avatar
senix
since it is emissions I bet disconnecting and turning on the lights to ensure a complete discharge should work.
I would remove both terminals myself.
btdrygulch
1983 - 2012 Ranger & B-Series
Mar 26, 2025 09:35 AM
andysam
Mar 17, 2014 02:50 PM
VTX1800rider
May 21, 2013 07:18 PM
ccarrier
Sep 27, 2010 11:53 AM
DRRXR
Aug 17, 2009 04:25 PM
