Engine Run-on.
Old Jul 20, 2003 | 02:09 AM
sweetpearl's Avatar
sweetpearl
Question Engine Run-on.
please help me...my 79 f-150still sounds like it is on even after the motor has been turned. it is not as loud as if it were on but it sounds maybe like a fuel system. any advice for me ?? also does anyone have a wiring manual for this year?? i would really appeciate it! thank you for taking the time to read and respond to this
Old Jul 20, 2003 | 02:17 AM
Torque1st's Avatar
Torque1st
Posting Legend
Engine Run-on.
???? Sorry, I can't figure out what you are talking about.
Wiring diagrams are available in the OEM factory manuals available on CD at the online store here.
Old Jul 20, 2003 | 09:56 AM
clean79150's Avatar
clean79150
Engine Run-on.
Does it sound like a deisel engine after you turn off the ignition?
If so, could be your carb settings or your timing.
Old Jul 20, 2003 | 11:16 AM
jor's Avatar
jor
Engine Run-on.
Yea, is it coughing and sputtering (trying to run but failing) or are you hearing a whirring sound like an electric fuel pump, electric fan or something?
jor
Old Jul 20, 2003 | 05:07 PM
76supercab2's Avatar
76supercab2
Engine Run-on.
The coughing and sputtering is called dieseling. Try reducing the idle speed. Should be a little set screw on the throttle linkage on the driver's side of the carb. You may have to remove the air cleaner to see it. If the idle speed is too high the motor sucks in a little gas and the heat of compression ignites it.
On a 79 there might also be a dash pot that opens the throttle to idle during run and closes the throttle blades completely when the engine is turned off. Look for a cylindrical object with a plunger that acts as a throttle stop on the driver's side of the carb.
Old Jul 20, 2003 | 05:15 PM
Torque1st's Avatar
Torque1st
Posting Legend
Engine Run-on.
We still haven't heard from sweetpearl for a better description of what this truck is doing. There is nothing to "answer" yet.
Old Jul 21, 2003 | 09:15 PM
chado's Avatar
chado
Engine Run-on.
I think I'll hi-jack this thread.
My truck sputters when I turn it off, and I understand its a carb setting. I was at CT the other day and I saw a carb adjuster tool. Do I need one of these or will a regular screw driver work fine?
Chado
Old Jul 21, 2003 | 09:45 PM
jor's Avatar
jor
Engine Run-on.
Might as well highjack it because it seems to have run out of steam anyhow. Re a carburetor adjusting tool, you don't need one. A long thin screwdriver works fine on stock carbs.
jor
Old Jul 21, 2003 | 11:15 PM
Mil1ion's Avatar
Mil1ion
Engine Run-on.
You might have to look around for the perfect length screwdriver , like I did.
I don't like to reach in past the spark plug wires witha 7" or have my hand to close to the fan with a 24".
Old Jul 21, 2003 | 11:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
Engine Run-on.
I have a little screwdriver with about a 3" blade and 4" handle I use for carb adjustment. I found it under the hood of a car when I was 15. It didn't belong to the car owner so I kept it. Some mechanic somewhere lost a friend.
Old Jul 23, 2003 | 12:20 AM
cypress_303's Avatar
cypress_303
Engine Run-on.
some times it can be the carb gasket, if it isn't sealed properly it can diesel when you shut it off, it happened to me with a 300i6 when i put a new carb on it.
Old Jul 23, 2003 | 04:05 AM
Torque1st's Avatar
Torque1st
Posting Legend
Engine Run-on.
The user never has come back, they must have figured it out.
Old Jul 23, 2003 | 12:22 PM
Big F250's Avatar
Big F250
Engine Run-on.
Originally posted by Torque1st
I have a little screwdriver.
I BET HE DOES!!
Old Jul 23, 2003 | 01:29 PM
chado's Avatar
chado
Engine Run-on.
haha.
Old Jul 23, 2003 | 03:13 PM
Torque1st's Avatar
Torque1st
Posting Legend
Engine Run-on.
You guys have been peeking -hehe
19687.3idi
May 18, 2013 08:13 AM
ospreyguy
16
Nov 30, 2010 07:05 AM
Orr353
6.7L Power Stroke Diesel
May 7, 2010 06:08 PM
TheYeti
Modular V10 (6.8l)
Aug 14, 2005 01:43 PM
Shrapnel64
Mar 4, 2004 07:47 PM
