amp meter
Old Dec 26, 2014 | 02:18 PM
Liquid10Rider's Avatar
Liquid10Rider
amp meter
Hey guys has anyone ever installed an amp gauge in their trucks? and if so what kind, how did you install it and where did you get it?
Thanks
-AJ
Old Dec 26, 2014 | 02:37 PM
M-S-G's Avatar
M-S-G
Well...that's not really a thing.
The reason being is you would need to put in in series with both batteries.
AKA 100amps current flowing through it. Good luck finding one.
If you are thinking about measuring how much juice your truck draws, may I suggest this fabulous creation.
Amazon.com: ESI 301M Fuse Buddy Mini DMM Adapter: Automotive Amazon.com: ESI 301M Fuse Buddy Mini DMM Adapter: Automotive
You can get a self contained one from harbor freight for about 7$ too.
Old Dec 28, 2014 | 01:47 AM
JSchuricht's Avatar
JSchuricht
What you need to look for is a shunt with a meter. The shunt is what goes in series with the battery or whatever your measuring then you use two small wires to measure the voltage differential and calculate current. Your best bet is to look at solar and electric vehicle suppliers.
Old Dec 31, 2014 | 08:51 PM
landmobile's Avatar
landmobile
Here you go:
Transportation Safety 180 0343 200 Amp Ammeter | eBay
They are not hard to install. The shunt goes in series with the batteries and vehicle electrical load (everything EXCEPT the starter) and the meter goes in parallel across the shunt.
seagiant
Electrical Systems/Wiring
13
Jun 9, 2016 05:38 PM
JWA
13
Jun 21, 2013 05:51 AM
jimlj
Aug 19, 2007 11:00 AM
Scout
Apr 26, 2007 09:31 AM
bryanknie
17
Jun 25, 2002 02:33 PM
