belt issue
Old Dec 26, 2014 | 02:17 PM
Liquid10Rider's Avatar
Liquid10Rider
belt issue
Hey guys its been a while since I have been on here but lately I have noticed im going through belts like crazy. they arent shredding or breaking but they start to squeak not to long after i put a new one on. now heres the thing, everytime i have changed my belt i changed the tensioner. and the problem went away but this time I changed the tensioner, and the idlers with an older belt and it still sqeaked. The belt was a napa green stripe, the tensior and idlers were also napa. I know its just a squeak but its very very annoying. also i did notice that there is some wear on the tensioner where you put the 1/2 drive ratchet. along where the back side of the belt just rides over. the truck also has dual alternators which were changed about 2 years ago or so and the water pump about a year ago.
maybe someone could help with this.
Thank you,
AJ
Old Dec 26, 2014 | 02:49 PM
M-S-G's Avatar
M-S-G
Since you replaced the tensioner my bet goes onto the water pump. Do you know how many miles are on it?
Easiest way to check is to remove the belt from tensioner and wiggle the waterpump shaft up and down. Acceptable lateral play is close to zero.
WP is not hard to replace and can e had for <$200.
Get a new thermostat and MIND THE ELBOW while you're at it.
Note, you might not be able to see any play while the car is idling due to low RPM and fan clutch slipping, that is why removing the belt is a good way to check whats up.
Good luck and please report progress!
Old Dec 26, 2014 | 03:09 PM
Liquid10Rider
in my original post i stated that the w/p was changed around a year ago. probably about 30 k on it now. and i did check for shaft play and everything checks out perfect.
-AJ
Old Dec 26, 2014 | 03:26 PM
M-S-G's Avatar
M-S-G
-AJ
Did you check with the belt out?
Old Dec 26, 2014 | 03:33 PM
ScaldedDog's Avatar
ScaldedDog
AJ, are you paying for belts and tensioners every time, or are they replacing them for free? I suggest you try an OEM belt and tensioner. Riffraff has 'em pretty cheap, as does Tousley. I know that's hard to do if the replacements are free, but if you are going to have to spend money, anyway, it may be time to try something different.
Mark
Old Dec 26, 2014 | 03:36 PM
M-S-G's Avatar
M-S-G
Mark
I have to say since Tousley changed to Autonation I no longer recommend it. Ever since the ownership changed the website is useless.
Bearing that in mind the service over the phone is still excellent.
Old Dec 26, 2014 | 03:53 PM
auden's Avatar
auden
My squeaky belt issue went away after I removed an aftermarket belt and put on an OEM. Original tensioners et. and on second belt after 225000 miles.
Old Dec 27, 2014 | 06:51 AM
jgilrfr's Avatar
jgilrfr
is there a chunk of an old belt stuck anywhere on the pulleys or a scratch or nick in the old pulleys?
Old Dec 27, 2014 | 09:58 PM
carl2591's Avatar
carl2591
have you tried the Gates FleetRunner belt.. its a high performance belt for the 7.3L engine. I read about them from a guy and his wife that goes around the world in a ford diesel.
they use and recommend the gate fleetrunner belt.
Old Dec 28, 2014 | 01:24 PM
HD Rider's Avatar
HD Rider
I am running a fleetrunner belt with Napa tensioner and no problems.
scottman70
Dec 27, 2015 03:29 PM
greenf150flareside
Sep 10, 2015 10:59 AM
JamesHajek
24
Mar 12, 2012 06:55 PM
pipesalesman
Feb 6, 2007 01:28 PM
GSDogs
Jun 10, 2006 07:18 AM
