Sponsored by: Real Truck
2008 Gauge cluster interchange
Old Jan 15, 2015 | 06:11 AM
CircuitBoardMedics's Avatar
CircuitBoardMedics
The PATS system is only looking to match the key information to the cluster programming when the ignition is initially turned on. It doesn't constantly scan for safety reasons, because if it did the truck could potentially shut off while driving with a momentary glitch in the system. So, your experience with the truck continuing to run when you pulled the cluster but failing to restart is normal.
Old Jan 15, 2015 | 08:03 AM
Shovelheadrob's Avatar
Shovelheadrob
I had an '07 F150, had the same issue, I had a new cluster fitted but had to have it configured on the Ford IDS system, doesn't have to be done by a Ford dealer, just someone with IDS which I assume CircuitBoardMedics have.
Arizona97
Dec 20, 2017 05:35 PM
roy.prue
Mar 17, 2015 06:21 AM
Yahiko
Mar 30, 2013 04:40 AM
90pioneer
Feb 26, 2013 09:08 PM
1tiredjarhead
1997 - 2003 F150
18
Feb 12, 2007 06:41 PM
