Headlight keeps burning out..
Old Dec 22, 2014 | 05:27 PM
cryptyx's Avatar
cryptyx
So my drivers side headlight for low beams keeps burning out, im assuming this has to do with a short somewhere but i haven't had the time to really check it out. I do notice that when i originally went to switch the bulb, part of the upper headlight housing had a hole in it as if it melted at some point. Should i be checking for proper grounding? Maybe a relay? I'm not the smartest guy when it comes to electrical, any help is appreciated
Old Dec 22, 2014 | 07:22 PM
*2fords*'s Avatar
*2fords*
Is water getting in there and hitting a hot bulb?
Old Dec 22, 2014 | 11:07 PM
choate's Avatar
choate
Yeah these things are prone to leak and will fill up w water. The "solution" is to drill a hole to allow water to drain. If its done at the top that is probably allowing water to run down onto the hot bulb possibly.
Old Dec 22, 2014 | 11:14 PM
JWC 3's Avatar
JWC 3
Check the plug also . Burnt connections will cause high resistance and cause shorter bulb life .
Old Dec 23, 2014 | 02:29 AM
cryptyx's Avatar
cryptyx
Thanks for the input gentlemen, i'll check it out in the morning
Old Dec 23, 2014 | 10:08 AM
rugermack's Avatar
rugermack
Start with the grounds
Old Dec 23, 2014 | 01:28 PM
Evan_P's Avatar
Evan_P
This doesn't sound like an electrical issue, especially if he has a hole in the top of the housing. I'm betting it's water getting in and fouling the bulb.
bittybear
Aug 26, 2017 03:27 PM
choate
Jul 18, 2014 06:46 PM
C120
General Automotive Discussion
Jul 16, 2013 08:16 AM
SKIRYDR
Jul 30, 2006 11:14 PM
mtuchris
Bronco II
May 12, 2001 10:56 AM
