1959 F100 Restoration Project
I have a 59 F100 that I just started working on after it has been sitting for a good 2-3 years. I'm new to working on motors and was hoping I can get any help to get it running right. It has the original 223 inline 6 that I want to keep in it but I'm having trouble getting it running. It appears to be a problem with the ignition because the engine turns but there seems to be no spark between the distributor and coil. Hope there's knowledge out there that can help me figure out this problem and again bear with me as I am new to working on engines. Thanks
Right on, someone should be by that can help you more than myself. The search feature is a great help, here is link when I searched "bad coil"-may have other information to help you out as well
Ford Truck Enthusiasts Forums - Search Results
Joe
Joe
I did just recently buy a new starter solenoid, that does make up part of the primary circuit correct?
Yes during the start cycle 12 volts are applied to the coil. With the key in the ignition position power to the coil is reduced through the resistor, keeping the points from frying.
A good investment for you would be a shop manual. You can pick one up on Evil bay either paper or CD.
Good luck and have a Merry Christmas!
