LED Lighting
Also pretty good customer service and I guess you could say they take care of their customers. I placed a big order, with every bulb I wanted for my truck, almost three months ago now. Got most bulbs in earlier and everything worked great, but didn't get to doing the tails and reverse lights till just before Thanksgiving. I did order oversize bulbs but hoped they'd fit, turned out the reverse bulbs were too long. Worked fine, but didn't fit in the housing. So I figured I was stuck with them since it was so long ago that I had ordered, but I went ahead and filled out their return/exchange form online. I wanted to exchange for new bulbs. It got approved right away, I couldn't believe it, and was busy at the time so didn't get around to shipping the bulbs back. I finally got around to calling them to confirm it last week, and sure thing they said they would accept the bulbs back in exchange for different ones. They only have a 30 day return policy after the day of purchase and this was over two months after I purchased, and they accepted it. I just told them exactly my situation and I guess they understood. I think probably because the bulbs worked fine and just didn't fit in my housing, they accepted it. It was also sort of on them because I did use their vehicle specific bulb-finder to find those bulbs. That's pretty good in my book.
Oh and if you get LED's for the turns and tails make sure you get resistors, otherwise you will get a hyper flash when using the turn signals. And make sure you use the right resistor for each one, they have separate ones for tails and turn signals. I accidentaly put the tail light resistors on the front turn signals, haha. The turn signals aren't picky, but the tail lights have to have the specific tail light resistor. So now I'm stuck waiting on the resistors to put my tail light bulbs in, because I got them along with new bulbs in exchange for the reverse bulbs that didn't fit. New bulbs were a little cheaper, just enough to cover the cost of the resistors.
Resistors work good though, haven't gotten to putting the tails in yet, but the fronts are working good. I did get my exchange back from superbright though. Only took them about a week or so after I sent the bulbs that I didn't want back, pretty good service.
