sludge on fuel filter
The lower fuel water separator must be full of that crud.
Normally algae is an almost black looking junk, but anything is possible. If it's above 10 degrees that certainly isn't waxing. I would look into adding a biocide or running a couple tanks of B20.
If it reappears then it would be time to drop the tank and boil it out.
Josh
Josh
Yep Algae,
If comes in green,black yellow tan/cream and clear.
Even after you clean the system you should run some
diesel algaecide treatment.
Maybe a little over kill here.
Dieselcraft.com Fuel Microbe Test Kits Fuel Algae Test Kits
Sean
Marry Christmas
Sean
Marry Christmas
