PCV Valve? Hose Assembly?
Old 12-18-2014, 07:12 PM
F TOO FITTY's Avatar
F TOO FITTY
F TOO FITTY is offline
So is there a PCV Valve on this generation of F150s? I thought there was a hose coming out of the passenger side valve cover; but when I called the dealer to inquire about the availability of the part, he said "its only to be serviced when servicing the valve cover"
What the heck? I figured it was time to replace it since my mileage has dropped a little bit lately. Truck has 45k on it. Any thoughts?
Brian
Old 12-19-2014, 04:53 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,230 Likes on 808 Posts
The change over to winter blend fuel to be a contributor to your MPG loss.
Old 12-19-2014, 11:15 AM
awq134's Avatar
awq134
awq134 is offline
Brian
My 2010 with the 4.6L has one and my maintenance manual suggests changing it every 60,000 miles.
Old 12-19-2014, 01:23 PM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is online now
Received 3,432 Likes on 2,347 Posts
The 2011 screws in (about a 1/2 turn) and has a o-ring seal that needs lube before install. On the 2009 buy a new PCV, rotate your old one counter clockwise and remove it and install the new. You can not reuse the old one as it will break the ears off when you rotate it.
Old 12-19-2014, 04:27 PM
meborder's Avatar
meborder
meborder is offline
my 06 expedition has the PCV valve integrated into the driver's side valve cover. I assume the newer ones are the same, but that may not be the case.
the owner's manual only says to check the pcv system flow at 100k or 150k, and that the pcv valve is not a item that gets serviced.
on the passenger's side valve cover, there is just a 1/8" hose fitting on which a hose connects up to the breather box by the throttle body.
I took all the hoses off mine to "check the system flow" and could tell absolutely nothing. it flows, but how much. if you plug the air inlet, it pulls a vacuum, and when you unplug the inlet you hear a rush of air going through the tube. so it flows, but how adequately is anyone's guess.
I've asked the question here in the modular engine forum, and nobody else seems to know how to test the system flow either.
I think the dealer gave you the correct information. the pcv valve is only serviced by replacing the driver's side valve cover. There is likely a pcv heater on the intake that can be replaced, but the pcv valve itself is integral to the valve cover.
to the best of my research, anyway.
I think what you are referring to is the pcv valve air inlet check valve, which mine does not have. but the actual pcv valve should be in the driver's side valve cover.
Old 12-19-2014, 07:14 PM
gDMJoe's Avatar
gDMJoe
gDMJoe is offline
F TOO FITTY - So is there a PCV Valve on this generation of F150s? I thought there was a hose coming out of the passenger side valve cover; but when I called the dealer to inquire about the availability of the part, he said "its only to be serviced when servicing the valve cover"
What the "dealer" said, since you have a 5.4L engine.
The 4.6L has a normal, serviceable PCV valve.
-click- the pic'
Goth 150
< This space intentionally -blank- >
NS70250
33
08-17-2016 11:50 AM
jerwiltho
05-07-2013 10:49 AM
rg200amp
1999 to 2016 Super Duty
05-02-2008 12:31 PM
DMBronco
1978 - 1996 Big Bronco
08-07-2005 02:11 AM
Saurian
18
04-22-2004 05:00 PM
Quick Reply: PCV Valve? Hose Assembly?
