02 supercrew heater problem
Old Dec 18, 2014 | 01:31 PM
krazykrenz's Avatar
krazykrenz
Marginal heat 5.4 f150 Supercrew. I have replaced the thermostat and flushed the heater core both ways till it ran clear (not much rust came out. I can hear the change in air flow so I know the blend door is moving.the hose coming from the front of the intake is very hot. the hose from the rear of the intake that comes from that small tube is not too hot. Which way does the coolant flow through the heater core?
Old Dec 18, 2014 | 06:15 PM
projectSHO89's Avatar
projectSHO89
No you don't. Those are airflow diverter doors, not the temperature blend door.
From the hotter side to the cooler side.
You still have inadequate flow through the heater core due either to a restriction, air bubble, or a weak pump.
Old Dec 29, 2014 | 02:29 PM
rickbrad's Avatar
rickbrad
How can I tell if the temperature blend door is working on my 2002 F350?
Old Dec 29, 2014 | 07:42 PM
projectSHO89
If you can control the temperature of the outlet air with the temperature control, the blend door is working properly.
Old Dec 29, 2014 | 08:12 PM
rickbrad's Avatar
rickbrad
My coolant overflow tank was dry and all my windows are fogging up when I turn the heater control **** into the red zone - so I'm pretty sure I need a heater core.
I am going to start searching, but if anyone knows of a good step by step guide to replacing a heater core, please reply or send me a PM.
Old Dec 30, 2014 | 05:48 AM
JWA's Avatar
JWA
There's more than a few YouTUbe videos about heater core replacement in the F-Series--give that a shot. Here's one to get you started:
thurston
Nov 26, 2015 11:13 AM
racer87f
1997 - 2003 F150
Jan 4, 2015 11:35 AM
yooper5.4
Jan 8, 2014 12:03 PM
Baggins
Aerostar
17
Feb 19, 2007 11:24 PM
bbwrench
1978 - 1996 Big Bronco
Dec 15, 2005 11:37 PM
