Super Cab windows
Old Dec 18, 2014 | 07:46 AM
SVTDriver97's Avatar
SVTDriver97
Super Cab windows
Not sure if this has been asked before, but i've been thinking about the trim on Super Cab windows with that splitter in the middle of it.
Would the interior panels from an 87-96 fit 80-86?
I know the extended cab window is just one window, but because of that trim it makes it look like two.
Old Dec 18, 2014 | 03:14 PM
f100beatertruck's Avatar
f100beatertruck
They changed it in 92. From what I've heard the window dimensions are different, but someone on the forum made it work. There's inside and outside trim. Not sure what's involved in the swap.
Old Dec 19, 2014 | 09:54 AM
SVTDriver97
I've tried searching the forum but can't find anything on it. Do you know who might have done it?
Old Dec 19, 2014 | 11:14 AM
mario9272's Avatar
mario9272
I have swapped the bottom panel out because I wanted cup holders in the back. there is a little bit of trimming that you will have to do on the top. And I had to cut a hole for the seat belts. I can take pictures of it when I am off work. Hope that helps a bit.
Old Dec 19, 2014 | 11:34 AM
SVTDriver97
That would be great.
Thanks
Old Dec 19, 2014 | 02:13 PM
f100beatertruck
https://www.ford-trucks.com/forums/1115258-project-smogie-racinndrummins-idi-build.html
Ok, so the 80-91 windows install from inside, the 92+ from the outside. The 80-91 opening is smaller, but can be made to work. It's not a bolt in, but it can be done. Look about halfway down the first page.
Old Dec 19, 2014 | 03:02 PM
SVTDriver97
Ok, but it is one solid window across all the model years right?
My main question is whether the interior trim will fit from a 92-96 style, because that's when the trim didn't run through the middle of the window?
Old Dec 19, 2014 | 07:20 PM
f100beatertruck
There's inner and outer trim. Yes the window is one piece, but I don't know if you can install it without the outside trim.
Old Dec 19, 2014 | 07:44 PM
ctubutis's Avatar
ctubutis
The parts book says it was one solid window per side 1980-89 BUT 1980/85 part numbers are different than 1986/89 which means something changed. This book only goes up to 1989, I have no idea when or if they changed again.
As for the interior trim, I've heard of it being done but at some point (I think in the 90s) they started including rear shoulder seat belts, the trim was made to accommodate that.
Old Dec 20, 2014 | 02:09 PM
mario9272's Avatar
mario9272
ere is a picture i said i would take
Old Dec 21, 2014 | 10:15 PM
SVTDriver97
That area near the rear of the panel....that's where the seat belt would normally go through right?
Old Dec 21, 2014 | 11:30 PM
mario9272's Avatar
mario9272
if you are talking about the hole at the end of the arm rest yes I believe. and the corner (at the back of the cab) is not quite flush against the top piece. I am not sure if it is not like that on the otherside
Old Dec 22, 2014 | 06:54 AM
SVTDriver97
Looks like it won't work. The plastic in the newer trucks are squared off at the end near the rear of the cab, so the top plastic doesn't match up.
Also, there's no way to make the lap belt hole line up, so looks like i'll have to abandon me idea.
Thanks for the pics.
bjmayberry2
May 28, 2017 01:53 PM
johnfin1
Aug 10, 2016 01:28 PM
Ltngdrvr
Ford Truck Parts for Sale
Mar 16, 2015 08:13 PM
hotrod_heart
May 6, 2014 05:05 PM
ns870
Apr 26, 2012 08:28 PM
