E5TZ-16138-B = With Standard Cooling / Obsolete ~ 1 available NOS
E3TZ-16138-F = With Extra or Super Cooling / Obsolete ~ No Ford dealer or obsolete parts vendor has any.
Originally Posted by wheelieking
Ok I found a good core support from a 94 f450 with a NA 7.3 non AC. My truck is a 94 f250 turbo 7.3 with AC. To the best of my measurements these cores are identical. If I find any discrepancies I will post them. Right now my core is still in the truck so I can't measure everything but the truck is stripped otherwise. If anyone wants any specific measurement let me know. I'm going back out to the garage tomorrow.
looking at the parts chart, it appears that the most noticeable difference is the height of the radiator opening
I think the exception to the rule that you might have found is that it comes from an F450 and not the 250 or 350. The F-super duty's probably all came with the tall radiator for the extra cooling capabilities.
don't quote me on this lol but i think i read that the different rads/supports ended with the 8th gen trucks.
iirc (and again,im just going off memory here) all 9th gen diesel trucks (92-97 idi-psd) f250-350-350c&c-f450 all use the same large rads.there was no longer a short wide rad version.be it regardless if the truck was equipped with a/c or not.....again don't take my word for it though.just seem to recall reading this to be the case is all.
