Will not start back up after Driving
Old Dec 16, 2014 | 04:21 PM
garycd's Avatar
garycd
Will not start after driving
When I Put the ohm meter to the two post on coil I get no ohm reading 0.0 Don't know if that is open or shorted. Yes the book is saying 0.8 to 1.6 ohms on the primary coil resistance.
Thanks.
Old Dec 16, 2014 | 04:31 PM
Gary Lewis's Avatar
Gary Lewis
My DVM's show "---" for open and they count down to zero for a dead short. In other words, if you put the meter's leads together you'll see it start counting down from something like 99 ohms, dropping rapidly, and then taking a couple of seconds to hit "0.0".
If your coil has a dead short then you will probably have fried the DS module.
Old Dec 16, 2014 | 04:40 PM
garycd's Avatar
garycd
Is the DS the Distributor stator? Thanks.
Old Dec 16, 2014 | 04:46 PM
Franklin2's Avatar
Franklin2
Silver box on the fender.
Old Dec 16, 2014 | 05:03 PM
garycd's Avatar
garycd
Are you saying the Duraspark Ignition Module box?
Old Dec 16, 2014 | 05:33 PM
Gary Lewis's Avatar
Gary Lewis
Yes. If you've been running the engine with a shorted coil the DS box may be damaged. And it is probably what is failing.
Old Dec 16, 2014 | 05:54 PM
garycd's Avatar
garycd
I did try a new after market DS box one day when it would not start up and it did not start with the new box.Don't know if a after market works or not on the DS systems. Would you know if I put a new coil on would the bad DS box fry the new coil? Sorry to keep bugging you guys on this.
Old Dec 16, 2014 | 05:59 PM
Gary Lewis's Avatar
Gary Lewis
No, I don't think a bad DS box will fry a coil. It could if you turned the key on and left it forever when the box was placing a ground on the coil, but I don't think that's the way the box fails nor that you will turn the key on and walk away for hours if it did fail that way. Instead, I think the coil is either the wrong one or has shorted internally and the extra load is frying the DS box. And each time you drive it takes less time for the box to fail.
Old Dec 16, 2014 | 06:05 PM
garycd's Avatar
garycd
Thank you so much for your time.I will up date you when I get her fixed. Thank you.
Old Dec 16, 2014 | 06:09 PM
Gary Lewis's Avatar
Gary Lewis
Coils aren't too expensive, so with the reading you got on resistance I'd replace it first. The box can't hurt the coil, so even if it is failing you will have taken one positive step toward fixing things. Then, if the symptoms persist you'll have to replace the box.
Glad to help you like the guys on here have helped me.
Old Dec 17, 2014 | 06:36 AM
JayzDaddy's Avatar
JayzDaddy
Years ago on a 318 i had a similar issue. Mine would not cut off on me but wouldnt restart for a couple hours after i shut it off. I didnt know all of these tests then so i cant say if coil had fire but mine ended up being a pick up coil in the distributor.
Old Dec 17, 2014 | 07:52 AM
Gary Lewis's Avatar
Gary Lewis
In the light of day I realize that some things don't add up. Your coil cannot be shorted to the point it has 0.0 ohms and still work. Nor can it show 7V when running if shorted that badly.
So I'm now doubting the testing procedure. Did you have your meter in the lowest range of resistance? Something isn't right and I wouldn't buy a bunch of parts based on those tests until we figure out what.
Old Dec 17, 2014 | 08:00 AM
  #28
Franklin2's Avatar
Franklin2
I haven't liked this thread from the beginning. Why are we testing all these ignition components when he said in the first post that he had spark? And he said he also had fuel.
Old Dec 17, 2014 | 08:06 AM
  #29
Gary Lewis's Avatar
Gary Lewis
Good point, Dave. This is the one where it seemed the choke is stuck on. I'll wait to see the results of the choke testing before chiming in more.
Old Dec 18, 2014 | 02:34 PM
  #30
garycd's Avatar
garycd
You guys are right.I had the meter set wrong.Went to part store and checked a new coil and got the same reading.Sorry about that. Moving on to check wire harness and dist pickup,stator.
