Stupid question, but how do you stop a F100 glove box lid falling down?
Hello, my 56 glove box lid keeps falling down as I drive. I put new springs on it, but no luck. There is no latch on them I have seen in any pictures, maybe I should just put a magnet behind the dash.
Check the play in the hinge pivot, for excesive wear. The spring is the only one keeping it cloved
http://dinnerhillspeedshop.blogspot.se/2014/11/glow-box-tear-down.html?m=1
I have a 56 Custom cab glove box door assembly that's chrome plated that I removed when I filled the hole in the dash (my AC took up most of the space behind the door leaving a shallow compartment not large enough for a pair of sunglasses) I also have the short box.
I use a small round magnet has not fell open since.
There really is not too much to it is there? I will take the hinges out and see if I can tap the hinges a bit to tighten them up and if it does or not, put a magnet in there as well. I wonder if a little dust on them for grit to stiffen them up would help. Thanks for your interest and comments regarding this problem, thank you.
Unless chromed was a factory option, mine is aftermarket or custom plated (?) I haven't look at it in some time, I'm not sure if it locks, has a pushbutton or is like stock.
Perhaps custom plated, mine is also chrome as well as the steering column, so custom plated for mine I think.
