Just photographs
Old Dec 12, 2014 | 05:37 PM
Rimrock F1's Avatar
Rimrock F1
Just photographs
I plan on doing a build thread for my wife's 52 "Belle" in about a month. Since I know there are a couple guys on here that like photographs here are a few.
As of today my wife and I have been working on Belle for two months.
October 12th, the start.
October 13th, down to the frame.
December 12th, Coyote fits fine.
December 12th, TCI front and rear suspension.
December 12th, filled and bled clutch and brakes today.
December 12th, fuel pump and filters.
December 12th, checking running board clearance.
Old Dec 12, 2014 | 06:16 PM
tinman52's Avatar
tinman52
Welder User
Dude, your garage is WAY too clean!!!!!!
Nice progress in a short amount of time. Keep those pics coming!
Old Dec 12, 2014 | 06:17 PM
raytasch's Avatar
raytasch
Believe Nothing
That is going to be one fine truck. But, that looked like one fine truck in the before picture.
Old Dec 12, 2014 | 07:00 PM
Harrier's Avatar
Harrier
Wow! Nice garage and nice truck. I'm looking forward to watching your progress.
Old Dec 12, 2014 | 07:02 PM
jmerson's Avatar
jmerson
I thought he was working on the truck in his living room. Way too nice for a shop!
Old Dec 12, 2014 | 08:24 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
I agree "nice garage", it's cleaner than my house LOL. Wow you and your wife have sure got a lot done in two months. Belle is really clean now, I'm eager to see what else you have to show. Nice job
Old Dec 12, 2014 | 09:43 PM
Okiedokie's Avatar
Okiedokie
I couldn't get that much done in two months even if I never slept. Gonna be nice.
Old Dec 13, 2014 | 09:21 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Very Nice Truck & Shop. Wish my shop looked that clean
Old Dec 13, 2014 | 09:50 AM
FortyNiner's Avatar
FortyNiner
Apparently, you haven't really spend enough time pondering getting kicked in the nuts. Little disappointed in your priorities, mister. Tearing a truck down to the frame, mounting a new go-go, checking fit, scrubbing every trace of crud and juice from the floor of your garage floor. What are you thinking? Now the rest of us schlubs have another impossible standard. Between you and Wally, I'm about ready to surrender completely and sit around watching the Velocity Channel all day.
(Great looking build, by the way. Now go put your cape on and perform another super-human feat. Go ahead, shoo.)
Old Dec 13, 2014 | 12:27 PM
Rimrock F1's Avatar
Rimrock F1
The shop is clean because I don't have very much room and it fills up with stuff fast if I don't keep it that way. Project is moving along well because my wife works with me and the truck is in such good shape I don't have seized bolts, repairs and rust to deal with. Today's project, get the cab inside and on it's back so we can work on the bottom.
Finally found some rust under the truck and under the cowl. I feel for all of you in the rust belt.
Old Dec 13, 2014 | 12:28 PM
Rimrock F1's Avatar
Rimrock F1
Wife and I brought the cab inside and set it on it's back. Wife's comment "that was easy".
Super clean for a 62 year old truck.
Old Dec 13, 2014 | 12:37 PM
FortyNiner's Avatar
FortyNiner
Pity rust? Seriously?
Old Dec 13, 2014 | 12:47 PM
AXracer's Avatar
AXracer
I'm curious about your fuel pump choice/location. Electric pumps are designed to push rather than pull, so all the manufacturers I am familiar with recommend mounting the pump as close to the tank as possible. Where are you mounting your tank? Are you going to run a return line from the pump to the tank or does the Coyote return from the fuel rail? Why did you chose to use an external pump with the coyote rather than an internal one like is almost universal with modern high pressure EFI and much easier to install/plumb?
Old Dec 13, 2014 | 12:58 PM
Rimrock F1's Avatar
Rimrock F1
Ax, I debated the fuel pump for quite awhile. I am using a modified stock tank with a return. The tank gravity feeds the pump. I know there has been debate about bottom outlet fuel tanks and fuel leaks but feel if done properly it is as safe as a top fuel pickup.
Old Dec 13, 2014 | 03:05 PM
AXracer's Avatar
AXracer
The major safety consideration would be that the outlet and line be above the bottom of the frame and/or be protected by a substantial skid plate. The danger is high centering the vehicle and ripping off the outlet. Not all states with vehicle inspection laws will pass a bottom outlet tank. If the pump is mounted higher than the tank outlet, it is no longer being gravity fed once the fuel level drops below the pump.
EDIT: see my new topic: new fuel pickup
