Modular V10 (6.8l)
350 V10 lacking everything. What first?
Old Dec 11, 2014 | 06:59 AM
Referencedesign's Avatar
Referencedesign
First post. Great site. Be gentle.
I bought an F350 V10 (2004) about a year ago. 4WD and probably 3.77 RE with the 4 speed. First tow was a 42' fifth wheel at 14Klbs. Lets say the experience was eye opening. 13mph on the freeway from ABQ to Taos was not inspiring. A F450 dually 6.2 fixed the tow issue. Now I have a daily truck (the 350) that still seems like it struggles to pull itself.
After scouring this site the rear end ratio seems to be my biggest problem. Since I drive a lot from NM to Georgia and back, mileage would be a priority with occasional towing so keeping the 3.77 might help there.
Q: does getting the rpm up on the V10 under light load save fuel? Set of 4.10 rings?
Next area would be a tune. Helped a lot on the 450.
Q: Is there a tuner that can quickly switch between econ and power less the 20 min full program?
Last Q: Any other known performance issues to check .. coil packs maybe. Got a slight lump in the idle which should be silky smooth for a 10 cylinder. Any tricks to find the offending pack?
Old Dec 11, 2014 | 11:21 AM
truckfella's Avatar
truckfella
Your driving between NM and Georgia, is that towing or unladen?
Old Dec 11, 2014 | 12:02 PM
Hank85713's Avatar
Hank85713
I have an RV with the v10, I got the 5star rv tuner and it does help. But that is a different vehicle from yours. Check out this link:
https://www.ford-trucks.com/forums/9...ky-thread.html and then make a phone call and ask your questions. This guy is highly recommended as a v10 guru. Like I said I have the rv tune so he also has others.
Most people with v10s dodge or ford do not seem to get impressive mileage any time. Friend had a dodge that siad it was like my old 69 charger, would pass everything but a gas station. He bought a CTD!
Old Dec 11, 2014 | 08:37 PM
Immortal_Ben's Avatar
Immortal_Ben
Tunes from Milke @ 5Star, fo sho.
Old Dec 12, 2014 | 12:11 AM
Referencedesign
Truckfella, 2nd time for the V10 no load. Not my first choice for that trip..usually the diesel Jetta at 50+mpg. Or the Raptor at 14.
Even the 450 got 16 unloaded.
Thanks for the tip Hank. I'll give them a call.
Old Dec 12, 2014 | 07:47 AM
WE3ZS's Avatar
WE3ZS
13 MPH? Or 13 MPG? One is pretty bad the other is pretty good if towing.
Many V-10 folks have gone from 3.73 gears up to 4.10 or 4.30 and have seen an improvement in city MPG and little to no change on the highway. Yes the V-10 like to rev and it's more efficient at slightly higher revs with lower throttle opening.
Using the SCT tuner from 5Star I swap tunes in about 2.5 minutes, truck must be shut off for this though, no changing tune on the fly.
Try unplugging one coil at a time to see if the "lump" goes away with the intentional miss.
Welcome to the forum!
woodysdrw
Jan 12, 2018 06:41 PM
james93
Apr 25, 2013 08:20 PM
caprang
Apr 13, 2011 04:10 PM
Skattracker3
Jun 16, 2009 08:10 AM
Rengaw
Modular V10 (6.8l)
107
Sep 27, 2006 03:53 PM
