Tach not working
Old Dec 16, 2014 | 05:48 PM
  #31
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
Does your truck run now? If it doesn't and the oil pressure gauge isn't working I'd have to wonder if there is a couple of wires shorted together in the harness farther up.
Old Dec 16, 2014 | 06:25 PM
  #32
drpaul311's Avatar
drpaul311
nope! after reading an earlier response, I should have known the oil sensor is on top of the hpop. when I rewired the cps, I never put those wires back on. that was my own stupidity and frustration getting the best of me.
Old Dec 16, 2014 | 06:31 PM
  #33
MOOSE_MACHINE
Ok. Is there smoke when it cranks.
Old Dec 16, 2014 | 06:33 PM
  #34
MOOSE_MACHINE
And did you try a new cps. Did you check the wires all the way up?
Old Dec 16, 2014 | 06:56 PM
  #35
drpaul311's Avatar
drpaul311
no. to me, that tells me the injectors are not firing, which is consistent with the tach not working!
Old Dec 16, 2014 | 06:59 PM
  #36
drpaul311's Avatar
drpaul311
yes and yes. ..
two ford dealers said my truck has a tach sensor on the fuel injection pump. is the pump the hpop? I thought the psd didn't have this sensor, but the IDI engins did/do.
Old Dec 16, 2014 | 08:26 PM
  #37
madpogue's Avatar
madpogue
NO tach sensor! Would the guy at the dealership have even been born when our trucks were built? I'd bet a nickel he wasn't working there when our vintage of truck was regularly serviced there.
Given everything you've had to pour into this truck, it's high time you got some device that communicates with it via the OBD-II port. That way you can see EXACTLY what it's doing (injection pressure, RPM, etc) while cranking.
Old Dec 17, 2014 | 01:31 PM
  #38
drpaul311's Avatar
drpaul311
Cool
i even questioned the dealers about this. their responses were, its right here...i even explained that the IDIs have them but the PSDs do not, and i explained that i don't have an injection pump; my fuel pump is mechanical and the only thing having anything with a sensor would be the HPOP. i still questioned them. they are idiots.
Old Dec 17, 2014 | 09:04 PM
  #39
drpaul311's Avatar
drpaul311
Cool
is there a place that makes an aftermarket engine compartment wiring harness? the idea of having a fresh harness rather than one that's aobut 20 years old seems to be a nice option.
Old Dec 19, 2014 | 01:08 AM
  #40
drpaul311's Avatar
drpaul311
Cool
Originally Posted by ReBilld
No tach usually mean bad CPS.
ok, now im getting desperate!
i pulled out my engine compartment wiring harness today, checking for the lack of continuity. my harness does not have any broken wires thereby affecting the CPS's ability to properly send a signal to the tach.
can anyone please provide me with some insight as to why my tach is not working and therefore affecting the ability of me being able to fire up my new engine?
in sum, the PCM was replaced and i put in a second new CPS. I found one broken wire. i fixed it, but still no fire.
help in this department would be so appreciative. ive even prayed for a miracle!
Old Dec 19, 2014 | 07:50 AM
  #41
madpogue's Avatar
madpogue
That "insight" will come, as said, from a diagnostic device connected to your data port. Without that, you'll be chasing your tail.
Old Dec 19, 2014 | 08:53 AM
  #42
Hussler's Avatar
Hussler
1. Have you checked oil level in the HPOP reservoir?
2. Measure voltage on ICP wire LTBlu/Red. You need at least 1 volt while cranking to have enough pressure to fire injectors. If you are getting CPS signal then it will probably ramp above 3 volts.
Some other voltage and resistance checks can be found here ...
97-15A 7.3L DI Turbo Workshop Manual
Don't have tunnel vision as some trucks don't register tac during cranking depending on the PCM version.
Old Dec 19, 2014 | 10:46 AM
  #43
drpaul311's Avatar
drpaul311
about the scanner device: for some reason my truck will not run with my scanner plugged in it. every time i have plugged it in to the obd port to read live data, my truck dies every time.
Old Dec 19, 2014 | 10:49 AM
  #44
drpaul311's Avatar
drpaul311
Cool
i will check this out after i put the harness back in.
for the record however, no tunnel vision here. while cranking, my tach does in fact register about 100-200 rpm, or at least it did before the engine swap.
Old Dec 19, 2014 | 01:39 PM
  #45
madpogue's Avatar
madpogue
What scanner are you using? A generic OBD-II scanner will do exactly what you describe.
