Glow plug controller??
Old Dec 9, 2014 | 03:51 PM
CGMKCM's Avatar
CGMKCM
My Nephew has a < 90k mile 1994 7.3 Turbo Diesel that does not want to start. Batteries are less than a year old, battery cables look good, cranks fast but does not want to start 40* temps.
So far, we changed the glow plug relay but it did not fix the problem. I suspect the glow plug controller has a problem but I know little about this system. Other advice given was change glow plugs but this seems unreasonable to me. Appreciate any advise.
Old Dec 9, 2014 | 03:53 PM
Chevy_Eater's Avatar
Chevy_Eater
Check out the FAQ and the stickies, TONS of information on the glow plug systems and how to test and repair them.
Old Dec 9, 2014 | 03:54 PM
Gettysburg150's Avatar
Gettysburg150
Either the controller is bad or the glow plugs are bad.
I put all plugs in my truck, still wouldnt start in cool temps, found the controller power wire was unhooked. Replaced it, figured it was unhooked for a reason
Old Dec 9, 2014 | 05:22 PM
tjc transport's Avatar
tjc transport
i ain't rite
it could be a bad controller, disconnected controller power wire, disconnected controller ground wire, or bad glow plugs. what type glow plugs are in it? if they are not motorcraft ZD-9's, my bet is they are probably bad and there is nothing wrong with the controller.
Old Dec 10, 2014 | 06:45 AM
CGMKCM's Avatar
CGMKCM
Sorry about not seeing the FAQs. I searched the site using 7.3l turbo diesel glow plug controller, nothing came up, so I jumped on posting.
The truck has the factory original glow plugs and controller. It has about 90k miles. I will read through Faqs and see what I can figure out.
Old Dec 11, 2014 | 08:10 PM
DmanNC's Avatar
DmanNC
Does your wait to start light come on? Mine did but just for a few seconds. After I replaced the controller it started just fine. Of course this was after I solved all of air intrusion issues first.
Forddiesel17
16
Mar 20, 2016 08:08 PM
DmanNC
Aug 27, 2014 03:34 PM
66f100prostreet
Nov 14, 2009 09:35 PM
countrysF250
17
Nov 2, 2007 08:32 AM
79man
Dec 1, 2005 06:49 PM
