engine trouble. help with diagnose please.
Old Dec 9, 2014 | 02:04 PM
winginit's Avatar
winginit
my 74 f350 sat for a week, the engine is a 351m or 400 ,not original to the truck. I started it. it ran for about a minute with my foot on the gas to warm her up. i backed off the throttle she just quit fast, and wont start now.
i have power to the coil, and the test light lights up from negative on the coil to positive on the batterie. i did go to napa and buy and replace the coil anyway .
it gets gas to carb and i spray either and nothing,
i thought maybe i flooded it, let it sit overnight and today no start.
its raining now but what is next to try? thanks
Old Dec 9, 2014 | 03:45 PM
Byrd.Dog's Avatar
Byrd.Dog
Well, if it won't fire with ether, I'd look to the ignition system next. Sounds like you verified that the coil is good; check to see if you're getting a spark.
Old Dec 9, 2014 | 04:35 PM
winginit's Avatar
winginit
yes i will when the weather breaks. i am ttrying to get a jump on what it could be.
thanks
Old Dec 9, 2014 | 08:22 PM
winginit's Avatar
winginit
well i just tried to get spark from the coil wire grounded to the block and no spark.
the coils is good.
what should i try next?
thanks
Old Dec 9, 2014 | 08:28 PM
JWC 3's Avatar
JWC 3
What type of ignition are you running ? Points , Ford duraspark , MSD ...? Sounds like an igniton problem for sure .
Old Dec 9, 2014 | 09:25 PM
winginit's Avatar
winginit
old school points, should i pull the distributor or change points and condenser first.
can the points just stop working like that ? thanks
Old Dec 9, 2014 | 09:34 PM
JWC 3's Avatar
JWC 3
Yes , points can stop just like that . Get a new set of points and a condensor . Check the wiring coming out of the dizzy while there .
Old Dec 9, 2014 | 09:36 PM
winginit's Avatar
winginit
thanks, i will change out the points set , and post back my results.
Old Dec 9, 2014 | 09:41 PM
JWC 3's Avatar
JWC 3
One more thought ,,, make sure the rotor button is turning while the engine is cranking ...
Old Dec 9, 2014 | 09:43 PM
winginit's Avatar
winginit
If it don't then the timing chain popped, correct ? Thanjs
Old Dec 9, 2014 | 09:49 PM
JWC 3's Avatar
JWC 3
Timing chain or gear ... or dizzy gear sheared or loose . Hope the points and condensor or wire inside the dizzy is grounded out .... Best of luck ! Let us know what you find .
Old Dec 9, 2014 | 10:19 PM
Tedster9's Avatar
Tedster9
Try to use genuine Autolite condenser and points, the replacement points available today are mostly junk and the condensers even worse.
Old Dec 9, 2014 | 11:21 PM
winginit's Avatar
winginit
Will the points be junk if the condenser wire is grounded, even after I fix the short ? Thanks
Old Dec 9, 2014 | 11:35 PM
351Cleveland C4's Avatar
351Cleveland C4
No, the points would've ok.
Old Dec 10, 2014 | 08:58 AM
Byrd.Dog's Avatar
Byrd.Dog
I personally wouldn't invest too much time & money into making the old school points & condenser work when there are so many electronic ignition options available.
