supercharged 4.6
Old Aug 8, 2003 | 09:25 AM
martymart's Avatar
martymart
supercharged 4.6
I was in the Jegs website and a Ford Racing 5.8L/351 4V - 250 HP Heavy Duty motor was advertised for under $3,000. That's less than a supercharger. The cost to install the motor and I don't know if the parts, such as the throttle body, are interchangeable with the 4.6L may end up costing quite a bit more.
Any mechanics out their that could provide me with some info. Please keep in mind that I am looking for power for towing not necessarily for daily driving. Also the 91+ octane required for a supercharger is another expense I really don't need here in California.
Thanks
Old Aug 24, 2003 | 08:01 AM
ScubaSteve's Avatar
ScubaSteve
supercharged 4.6
I too looked at that 5.8L 351 in the JEGS catalog. It'll take a bit to swap these engines as they're two totally different block styles. I'm leaning toward the supercharger as the way to go.
Old Aug 24, 2003 | 08:08 AM
ScubaSteve's Avatar
ScubaSteve
supercharged 4.6
Sorry for the doublepost, network problems. Probably that SoBig worm.
Old Aug 24, 2003 | 08:49 AM
NewHolland's Avatar
NewHolland
supercharged 4.6
Have done Ford engine swaps for many years guys for my own enjoyment.. I dont think putting a 351w in where the 4.6 was would be a very fun swap..it would turn into such a headache you would be frustrated as hell..I'm sure it can be done..but I would highly discourage it due to its complexity..Stck with the bolt ons..And if you want real power,go for the supercharger.Its the only bolt on that REALLY works wonders..Allen engineerings eaton blower would be my choice for depedable big block like performance.Theres a reason Ford chooses Eaton blowers for the HD and the Lightning.Dependable performance!! They spent hours and hours and dollars researching it.I think it would be smart to follow ther reasoning for choosing this route for more performance...Just my 2 cents worth..
Old Aug 24, 2003 | 08:54 AM
NewHolland's Avatar
NewHolland
supercharged 4.6
To learn something about supercharging Fords..go to this link.http://home.att.net/~jroal/ He understands forced induction very well.Be sure to read all the links to educate yourself well.I keep it in my favorites just in case...
Old Aug 25, 2003 | 03:44 PM
ScubaSteve's Avatar
ScubaSteve
supercharged 4.6
I've been doing a bit of research, and found a supercharger that easier on the budget. The website is http://proficientperformance.com/Mer...&Store_Code=PP
If anybody knows of this products performance, please let us know of your experience.
Old Aug 25, 2003 | 04:06 PM
MrBSS's Avatar
MrBSS
supercharged 4.6
Personally, I'd feel better with the Eaton type. That's what Ford uses on the Lightning and HD. Also, GM uses it on the Supercharged 3.8 Buick, which I've run about 260,000 miles on!
This could be fine though. I wish I were able to supercharge my Ford! Please post your experience if you do it.
Old Aug 27, 2003 | 07:18 PM
Jimbo302's Avatar
Jimbo302
supercharged 4.6
Originally posted by MrBSS
Turbochargers become a lot more complicated as a retrofit, and they generally are for high RPM horsepower as opposed to low RPM torque.
Umm no.
Old Aug 27, 2003 | 07:29 PM
Jimbo302's Avatar
Jimbo302
supercharged 4.6
Originally posted by NASCARTruckDude
Would a turbo or twin turbo perform just as well as a supercharger. I know turbo's can have what they call turbolag but superchargers can cause parasitic loss to the motor.
Do they even make turbos for F150's?
Which one is better in your opinion?
Chris
A turbo would not perform "just" as well as a supercharger. A correctly sized turbo setup would outperform any of them. People talk about "Lag" because that is the time before the turbo reaches full boost. Which happens earlier than with a supercharger. The power felt between 0psi and say 10psi is a drastic power increase and is easy to notice. Superchargers (being belt driven) are limited to rpm to make boost. They dont make full boost until (and only) at high rpm. A turbo makes full boost when spooled, regardless of rpm. This is why a turbo pulls so hard at a lower rpm and provides more low end than a comparable blower can. Ever wonder why all commercial tractor trailers run turbos? You can tune a turbo setup to do whatever you want. No pulley changes to move boost levels, just turn a turn of the wrist or push of a button. The performance potential is exponentially better. As far as difficulty of install? Its just simple piping.
Old Aug 28, 2003 | 04:12 PM
MrBSS's Avatar
MrBSS
supercharged 4.6
Well they both do the same thing; the difference is in how they are powered. A belt driven supercharger must run at a fixed ratio to the engine RPM, while the exhaust driven turbocharger depends on the exhaust pressure and turbine design.
The major design problem with turbochargers is in keeping the driven turbine (which is exposed to the hot exhaust) lubricated and turning freely at high RPM. Especially if shut down after a hard run, its very hard on the oil.
Not to say turbocharging couldn't be done, but I think you'll find supercharging is easier, more reliable, and more available.
Old Aug 28, 2003 | 10:13 PM
Jimbo302's Avatar
Jimbo302
supercharged 4.6
Turbo timers, oil coolers, synthetics, there are a variety of ways to ensure a long life for your turbo. And it isn't hard on the oil, its hard on the bearings in the turbo.
True that, for a novice or bolt-on type of person, the blower is probably the easiest way to go.
Chris Karsseboom
2004 - 2008 F150
Mar 10, 2017 08:47 AM
Shovelhead 93
1997 - 2003 F150
Jul 27, 2015 06:05 PM
ewinglee44
Engine Swaps
Feb 15, 2014 11:00 PM
JF5speed
Modular V8 (4.6L, 5.4L)
Mar 21, 2005 08:38 AM
