help with blown circuit..
Old Jul 18, 2003 | 08:49 PM
theole34's Avatar
theole34
1989 f150 5.0 302 4x4
my headlights, taillights, dome, horn, radio, cig lighter all went out after a bad rainstorm. i have pulled all of the fuses, and they are good. i probed all of the fusible links and all are good for continuity. i am at a loss for an explanation here.
where should i be looking now.
additional - i have a set of KC daylighters wired into the headlights as well as a BS set of fogs on the same circuit.
any help appreciated.
robbie
Old Jul 18, 2003 | 10:18 PM
Franklin2's Avatar
Franklin2
Probe the fusible links for 12 volts. You may have a bad connection where they all tie together near the starter relay.
Old Jul 18, 2003 | 10:23 PM
theole34's Avatar
theole34
cool will do. right now they show continuity from the relay bolt. i did not check for voltage yet. i will though.
robbie
i may as well clean the whole damn post while i am at it.
Old Jul 19, 2003 | 03:13 PM
theole34's Avatar
theole34
all fusible links show good voltage on the side away from the relay. i found two wires that show some heat damage. lt grn/red and lt green coming from the brake light switch. still digging.
r
Old Jul 19, 2003 | 05:22 PM
ZombieSlayer's Avatar
ZombieSlayer
Have you replaced the relay?
Old Jul 19, 2003 | 05:51 PM
theole34's Avatar
theole34
would it be good to change the relay if the battery side and away side show good voltage. the black/org wire.. shows good voltage. at the fusebox.. #16 black/org - to - green/yellow shows 0 voltage. at the headlight switch the black/orange shows no voltage. i am beat right now.. spent all day tracing wires.
robbie
Old Jul 20, 2003 | 09:31 PM
steve83's Avatar
steve83
If the headlight switch isn't getting power, trace that wire back to the battery. At some point, you'll find the break in it, probably at a fusible link near the relay.
There's no need to replace the relay.
Old Jul 20, 2003 | 11:42 PM
theole34's Avatar
theole34
fusible link is good. getting 12+ after the relay. it has to be after the link and before the fuse box. that is a PIA to find. i am working hard to find it.
vacation now - will attack it again next weekend.
robbie
Old Jul 21, 2003 | 08:55 AM
steve83's Avatar
steve83
How far "after the relay"? Sometimes, the fusible link wires are 10" away from the relay.
bwolgie
Mar 11, 2015 03:35 PM
coalnation
Large Truck
Aug 1, 2014 12:00 PM
4fords
Electrical Systems/Wiring
Jul 16, 2014 02:17 PM
klebel
Oct 1, 2006 10:17 PM
mantta
Feb 18, 2002 08:26 PM
