Hello guys, I know this has been published many times before, but with new people coming in all the time i thought i would discuss the rust removal.
Presently I have 2- 30 gallion drums 1 with acid and 1 with molasses.
I have been doing the small quick things in the muratic acid and the bigger things in the slower molasses. However im thinking i really want to soak all my cabs in a large tank of molasses even if its only does a foot up the cab from the bottom. No one in maryland does this. Guys I have even thought of building a pit
and using a pond liner for my 4 cabs. Tell me what you think, someone talk some sence into me.
I tried the electrolisis thing and it only takes it off a straight line . The molasses
is suppose to be enviorment frendly so i could bury it and pull out the pond liner refill the hole.
I haven't heard of using molasses. If you have only moderate surface rust, how long of a soak would it take? I would be able to dig a pit and put a wading pond in it and fill it with molasses, though I think my co-workers would think I was nuts (which I don't care about, I even encourage that sort of thinking among them).
It would work. Might take a while, especially in the winter. Biggest problem I have with molasses is the smell. And insects love it. I prefer to use vinegar, but a pool full of vinegar would be expensive.
As for disposal, I dunno......the rust settles to the bottom of the container. Would still be a mess though. FWIW, vinegar is an excellent weed killer!
FWIW, the guys over on the FordBarn do the molassas trick with flathead blocks and swear by it. Seems like it takes a month or so and their only negative comments are it's a slow process and it does smell.
Ken
I used apple cider viniger and it worked pretty good. Till it froze anyways. I think your going to need a lot of molasses to soak a cab bottom. Might end up with a few deer in the yard too.
I have seen the results of the soaks on other things. Since i have 4 whole truck
cabs and fenders to do. I really want to get at least above the floor by 6 inches or so. Im on the east coast where rust is in every knook and cranny and since i have so much metal work to do Im looking for some shortcuts to get to it sooner.
I have used Vinegar many times with excellent results. As a rule unheated it takes about 2 weeks to soak heavy rust. The only downside is it is so clean it will start to rust again in minutes if something isn't applied to prevent it.
Its easy to see the before and after just 6 days. I put them back in for another week so i didnt spray them off. My pic is hard to see but it took off the rust and turned it into a brown gravy which when washed off is just metal and black converted rust
Ken
Except for the guy who completely ruined a crack-free block by leaving it in a couple days too long. Every machined surface looked like a golf ball, pits all over. As I recall he had to throw it away. There are so many faster, cheaper ways to clean a part, I just don't understand the attraction. Molasses works because it has sulfuric acid in it. Sulfuric costs a whole lot less and doesn't stink, but again there is a point where good metal starts disappearing, you need to be standing there when it happens. My machine shop charges $30 to thoroughly vat a block, not worth the trouble to do anything else IMO.
