Yet another EGR issue ?
Old Dec 7, 2014 | 01:34 PM
11jjonn's Avatar
11jjonn
my early '03 6.0
from 0mph, wot = accel sluggish to 2800rpm (hovers there), will not upshift, scangauge bst max'd at 4.0.
back off throttle = upshifts --- then ease more throttle to 40mph = pretty much normal accel, 18+ bst
egr data:
egr duty cycle% = varies -- idle = 15, cruise = 25
egr valve position desired% = erratic, 0-12
egr valve position measured% = 0 at all times
removed egr valve - covered with soot, no carbon build-up
clean with carb cleaner or soapy water??
how to test, to determine not frozen in closed position??
Old Dec 7, 2014 | 02:51 PM
11jjonn's Avatar
11jjonn
Used soapy water, lubed o-rings, reinstalled -- no help
guess it goes to garage monday............
Old Dec 7, 2014 | 05:14 PM
dannyboy950's Avatar
dannyboy950
First. What are you useing to get your values? We have another thread going you may want to read.
Old Dec 7, 2014 | 05:22 PM
11jjonn's Avatar
11jjonn
"scangauge bst max'd at 4.0."
If you're talking about the Torque app thread, I read that one - didn't help me
Old Dec 7, 2014 | 06:57 PM
dannyboy950
Since you read the thread you may have noticed the lack of information available.
Mainly because there is none to be had. Proprietary information.
Even if it was available to us there is nothing we could do with it unless we rewrote the PCM programming.
There is no adjustment or tweaking we can do. It is all controlled within the PCM programing.
All the egr does is open and close to allow spent gas [no oxygen] into the intake to control the air mix to control the combustion temps to stop the formation of Nox.
When it opens for how much and how long it opens is determined entirely by the PCM.
All we can do is keep it cleaned so it can work as commanded or replace it when it no longer works.
I have spent over an hour looking at DTC codes looking for values, lots of codes but not a single actual value. Oh some say the code is thrown if something exceeds a time limit but not what the limit was or inversely if it did not reach a certain point..Still no actual value..
Five pages of google search and nothing.
Not much help I know but the there is not much you can do either.
Old Dec 7, 2014 | 07:32 PM
11jjonn's Avatar
11jjonn
I'm not totally convinced my intermittent low power/low boost issue IS the EGR valve. I've even seen suggestions to just unplug it (which leaves it in the Closed position).
I've also seen a youtube video about a plugged MAP hose nipple (mine is clear) causing an issue exactly like mine.
Seems like a variety of conditions will tell the Turbo to take a "time out".
I probably need to connect truck to a "Big Boy" diagnostic machine, as my el-cheapo ScanGaugeII monitor leaves many questions unanswered.
Old Dec 7, 2014 | 08:17 PM
dannyboy950
A IDS would be the best source available. Did you also check your EBP sensor if the tube was clear?
Old Dec 7, 2014 | 08:35 PM
Money-Pit's Avatar
Money-Pit
What is ICP pressure and IPR % at idle?
Old Dec 7, 2014 | 10:42 PM
04badford's Avatar
04badford
By chance did you get the soapy water in the little holes there is a grey gasket that covers those holes , carb cleaner or water in the Electrical side will Damage the EGR Valve.
Old Dec 7, 2014 | 11:00 PM
jswartz84's Avatar
jswartz84
By programming EVD and EVM in my scangauge, I was able to diagnose a bad valve. The measured value didn't follow the desired very well.
If you unplug the EGR valve and the truck runs better, you found your problem.
So, what I have noticed with EGR operation is, It starts opening when the EOT/ECT are around 180°. After the initial open, it seems like it opens and closes with the throttle position and after a couple minutes of idling, it closes.
Old Dec 8, 2014 | 11:01 AM
11jjonn's Avatar
11jjonn
Haven't checked yet
800 26
soapy water in the little holes...
No, did not wet the solenoid or wiring connector area
unplug the EGR valve...
Results not consistent - sometimes would run normal 2-3 wot runs After disconnecting. At this point, 4-5 wot runs tested good.
Reconnect = more bad than good. Thought this was it !! .....however....
Disconnect = bad again ! ! ! ???
Only consistent is: runs normal, good boost as long as throttle not wide open.
1/2 - 3/4 pedal = slower to accel & build boost, but it will do both.
Old Dec 8, 2014 | 12:46 PM
Grant-Dieseltech's Avatar
Grant-Dieseltech
Being an '03 the PCM uses inferred back pressure from MAP and MAF sensor to control fueling. Either one can cause what your describing.
Old Dec 8, 2014 | 01:05 PM
11jjonn's Avatar
11jjonn
I have a new MAP sensor - will install if it ever quits raining (FL liquid sunshine lol)
BTW, my SG-II EBP reading is blank - - normal for 2003 ??
Old Dec 8, 2014 | 01:19 PM
dannyboy950
Now we need to see what is happening at the time of the event when it doesn't work and compare against what happens when it does run/accelerate etc.
Possibly need to add app values. See if there is a dead spot of the potentiometers.
App will show 3 values any 2 have to agree within 2 points/vlt. to work properly.
Old Dec 8, 2014 | 01:25 PM
11jjonn's Avatar
11jjonn
My APP (accel position %) reads 0 @ idle - varies, up to at least 90 upon accel.
Runs pretty much OK if I keep it under 75%.
(I don't have SG-II codes for vlt)
