tensioner pulley problem
Old Dec 7, 2014 | 12:41 PM
BocceMon's Avatar
BocceMon
My tensioner pulley is screeching like crazy for two weeks so I ordered a Gates replacement & it came in yesterday. The pulley is correct. My problem is that I cannot for the life of me get the retaining bolt to break free so I can replace the pulley. I am using a 18" breaker bar with no luck, both to the left and the right in case it is left handed. Is there something I'm missing?
Old Dec 7, 2014 | 01:55 PM
FordTruckDoc's Avatar
FordTruckDoc
What year truck? Which motor do you have? Mine was a T55 bit, and I used a manual impact driver to break it loose. Found the tool at Advance for cheap. Hit it with a hammer and it turns the bolt. I'm assuming you have tried PB blaster or freeze off already?
Old Dec 7, 2014 | 02:28 PM
BocceMon's Avatar
BocceMon
See siggie for motor info. Yes, tried everything I know of including having an 18 year old try w/o success. (I'm 68) Is this right hand or left hand threaded? Also, just to be clear, it is the pulley that rides on the belt to keep it tight.
Old Dec 7, 2014 | 09:29 PM
FordTruckDoc
Is the pulley squealing or is it the belt? I was thinking your tensioner was bad and you were replacing the whole piece. The mounting bolt for the tensioner and the pulley bolt are both left theaded.
Old Dec 8, 2014 | 08:19 AM
BocceMon's Avatar
BocceMon
Thank you very much. It is not the belt, it is the pulley. A little WD-40 & it quiets right down for a little while. I did the water test on the belt & it did not squeal at all. Thanks again!
Old Dec 8, 2014 | 10:43 AM
joegeds's Avatar
joegeds
I have a 96 straight 6 and I just replaced the pulley yesterday. Used a 16 mm wrench and it turned counter-clockwise to loosen. This is from the on-line manual:
<table width="95%"><tbody><tr><td>Section 03-05: Drive Belts, Accessory
</td><td align="RIGHT">1996 F-Series, Bronco Workshop Manual
</td></tr></tbody></table>REMOVAL AND INSTALLATION
<hr>Belt Tensioner Pulley Replacement
<table border="1" cellspacing="0" cellpadding="3"><tbody><tr><th align="CENTER" valign="bottom">Engine</th><th align="CENTER" valign="bottom">Tensioner</th><th align="CENTER" valign="bottom">Replacement Pulley</th></tr><tr><td align="CENTER" valign="top">4.9L/7.5L</td><td align="CENTER" valign="top">F5TE-6B209-CA</td><td align="CENTER" valign="top">E9TA-19A216-BA</td></tr></tbody></table>
Conditions requiring pulley replacement are excessive pulley wear or pulley bearing noise usually resulting from extended operation in abrasive off-road conditions.
Using a 16mm closed-end wrench, remove the drive belt (8620) according to the Drive Belt Tensioner, Automatic removal procedure in this section. Removal
NOTE: 7.5L (not F-Super Duty Motorhome Chassis) bolts have a left-hand thread, requiring clockwise motion to loosen the bolts. 4.9L and 7.5L F-Super Duty Motorhome Chassis idler pulley bolts, which loosen counterclockwise, have a conventional right-hand thread.
  1. NOTE: Excessive rearward force on the bolt during removal may overstress and crack the tensioner arm.
    NOTE: Pulleys being replaced for suspected bearing wear should be evaluated for rough bearings. Bearing noise that continues or rapidly returns after a replacement pulley is installed is usually belt chirp rather than worn bearings. Bearings should rotate smoothly with a slight resistance due to the permanent lubrication.
    Using the 16mm wrench, loosen the belt idler pulley retention bolt or nut.
  1. Remove bolt or nut and dust shield and remove the drive belt tensioner (6B209) from the tensioner arm locating boss.
Installation
  1. Replace the pulley and reverse the removal instructions observing the correct rotation of the retention bolt.
  1. Tighten bolt or nut to specifications.
Old Dec 8, 2014 | 11:08 AM
LeoJr's Avatar
LeoJr
For what it is worth, similar to the info joegeds posted, the 5.0 and 5.8 tensioner assembly bolt and the bolt holding the tensioner pulley to the tensioner assembly itself are both normal threads.
They are NOT reverse threads.
If you are standing on the passenger's side of the truck and the wrench handle is upwards from the bolt, you should be pulling it.
Not sure why it is fighting you so much. But possibly your lack of confidence that you are pulling in the correct direction has you holding back some of your strength? Get mad at it..
Old Dec 8, 2014 | 01:44 PM
BocceMon's Avatar
BocceMon
It fights me all the time 'cause it knows that I'm an old fart with minimal strength! I'm plenty mad at it...time for the cheater bar. I really believe that the former owner was a gorilla, everything on this truck is way over-torqued.
Old Jan 18, 2015 | 08:31 PM
BocceMon's Avatar
BocceMon
For what it is worth, I finally got it to break loose this afternoon. It resisited the whole length of the threads. I had to wire brush it to clean it up for re-install. The bolt that holds the pulley is LEFT hand thread.
Old Jan 19, 2015 | 07:58 AM
tjc transport's Avatar
tjc transport
i ain't rite
i wonder if the last person to touch it filled the threads with permanent locktite?
i saw that on a water pump. when asked why the fan had locktite on it, the idiot said so it would not come off. he was not happy when he had to fork over an extra $150 for a new fan and clutch.
Old Jan 19, 2015 | 08:26 AM
BocceMon's Avatar
BocceMon
It had to be something of that order. It took a while to clean the threads offt and it was uber gummy and hard. The female threads were worse. I used a tap for that and it worked okay. The PO must have been a gorilla because everything I touch on this truck has been way over torqued.
logger250
Mar 13, 2011 11:56 AM
Iallwork
Jan 12, 2010 06:11 PM
Paul Moody
Jul 9, 2008 09:58 AM
chief96
1983 - 2012 Ranger & B-Series
Oct 18, 2005 11:22 PM
