No spark
Old Dec 21, 2014 | 11:53 PM
Ghosttowner's Avatar
Ghosttowner
A direct replacement Ford TFI Coil by PerTronix D3003. 45,000 Volt. Summit Racing recommended it.
Old Dec 22, 2014 | 11:42 AM
rla2005's Avatar
rla2005
What is the primary winding resistance compared to a standard Ford coil?
Old Dec 22, 2014 | 11:45 AM
rla2005's Avatar
rla2005
I believe I am losing spark. Originally started stalling while driving, then would restart on its own before I could pull off road. Now when it stalls I have to get to a stop, turn key to off and retry to start several times before starting. I carry a spare ICM in glove box for when it won't restart. Taken ICM to parts store and they tell me it is bad. Last one a Mortorcraft test good several times. My original motorcraft ICM test good half of the time. The intermittent loss of voltage or short to the ignition system must be knocking out the ICM. The truck ran fine all summer, it was a problem that has gotten worse since last winter. I have done resistance checks on all ignition wires and to ground while moving etc. I think my next step is to hot wire the ignition with a dash mounted switch.
If the coil is getting hot anytime the key is in the On position, this is my interpretation of your statements, then you have a path to ground that saturates the coil.
Old Dec 23, 2014 | 09:37 PM
Ghosttowner
I ran a wire from battery to coil and cut wire from ignition supply. Truck stalled less than two blocks from house. Noticed new coil running hot. Was looking at wiring in book instead of looking at ignition, noticed a radio interference capacitor from coil ignition wire to ground. I located and removed filter? Test drove truck for several miles with no stall problems. Returned coil warm but not hot. Removed wire to coil from battery and spliced wire from ignition supply. Test drove truck again, no problems so far. My guess is the radio interference capacitor, was shorting out to ground intermittently. I will try to use it tomorrow for work, wish me luck. I have spent $100's and many hours hunting down a *&%#!$ $10 part. Thanks everyone for your help. The Ghosttowner
nostartnospark
Oct 1, 2016 09:33 PM
crucialprospect
Jun 24, 2016 03:21 PM
Stinky7-11
58
Oct 11, 2011 01:58 PM
fordbuddy
Apr 12, 2008 08:28 PM
Point Blank
Aug 27, 2005 05:27 PM
