Front diff torque
Old Dec 4, 2014 | 03:33 PM
Johnwb150's Avatar
Johnwb150
Front diff torque
Hey, I just replaced the front diff assembly on my 2010 F150, was wondering if anybody knew the torque for the 3 bolts that hold it in place... Thanks
Old Dec 4, 2014 | 11:05 PM
QwkTrip's Avatar
QwkTrip
Tighten to the standard for the thread type and material grade. Here is a random example from a Google search, Metric Bolt Torque Table - CNCexpo.com
Old Dec 5, 2014 | 08:46 AM
FireMe's Avatar
FireMe
111 ft-lbs.
Old Dec 7, 2014 | 10:58 AM
Johnwb150's Avatar
Johnwb150
Clonking/ banging noise
Thanks...so here's the deal...problem I'm having, I bought this 2010 f150 from the company I work for, front diff was shot, front drive shaft was in the bed, that's all I knew about the truck so I bought a complete front diff from a used place, it only has 58000km on it, good diff... So I installed the diff and the old front drive shaft, which doesn't seem to be in the best condition, now when 4 wheel drive is engaged I'm getting a constant clunk/binding noise from the front driveshaft area,,,, any ideas on where to start looking,thanks again
Old Dec 7, 2014 | 01:46 PM
QwkTrip's Avatar
QwkTrip
Are you sure the new axle is the same gear ratio as the back? Disconnect the rear driveshaft and see if the binding goes away. If it does then you got the wrong axle.
Old Dec 7, 2014 | 08:04 PM
Johnwb150's Avatar
Johnwb150
I will try this for sure, however the H9 code on the door sticker says it's 3:55 LS, that's what I hope I bought...thanks for the help
Old Dec 7, 2014 | 08:32 PM
paredneck33's Avatar
paredneck33
FWIW both the front diff and the rear diff should have tags on them that will tell you what gear ratios they each should have. And one other thing to keep in mind, using your rear end gear ratio at 3.55:1 the front diff may not be 3.55:1. It could be 3.54:1. The reason is so that the two diff. don't pull the truck apart. What you don't want to see is the rear diff with 3.55:1 and the front diff with say either the 3.15:1/3.14:1 or 3.73:1/3.72:1.
Old Dec 7, 2014 | 08:39 PM
Johnwb150's Avatar
Johnwb150
Other than the tag on the front diff plate, how could I tell what ratio it is...the tag on old diff isn't readable?
Old Dec 7, 2014 | 08:51 PM
paredneck33
Well you can jack the truck up and support it on jack stands. Mark a reference point on the tire and one on the u-joint yoke. Then rotate the wheel one full rotation and count the number of rotations of the yoke. IIRC 3.5 rotations of the yoke to 1 rotation of the tire gives you the 3.55:1 ratio. Or you could tear into the differentials and count the number of teeth on the ring gear and the number of teeth on the pinion gear do some math and find the ratio that way. Not sure of exactly how to do it this way, but a simple bing search will help get that info.
Old Dec 7, 2014 | 10:35 PM
Johnwb150's Avatar
Johnwb150
Thanks for the help
Old Dec 8, 2014 | 02:31 AM
QwkTrip's Avatar
QwkTrip
You can't do the tire rotation method on the front without removing the rear driveshaft or else the other front tire will spin and the driveshaft won't.
10 rotations of the tire is a lot better if you're getting down to the decimal place, which you are. A piece of tape on the tire and another on the driveshaft, and a piece of paper so you don't lose count.
Old Dec 8, 2014 | 06:00 AM
Johnwb150's Avatar
Johnwb150
Thanks for the quick response and help, I think I will start by counting the crown and pinion teeth from the old diff and go from there.... Live and learn... Glad it wasn't to big a job putting in the wrong diff lol
Old Dec 8, 2014 | 07:27 AM
Johnwb150's Avatar
Johnwb150
Well I just pulled apart the old front diff and got the ratio and it is indeed 3.55:1 thank god lol...now to find the problem! Again thanks for the info!!! Great Forum/Site
Old Dec 13, 2014 | 02:08 AM
QwkTrip's Avatar
QwkTrip
What was the outcome? I'm curious if you're going to have to go for transfer case.
Dude-Ford
13
Nov 27, 2018 08:13 AM
CommanderCrzy
Jun 8, 2015 01:48 PM
Johnwb150
2010 - 2014 Ford SVT F150 Raptor
Dec 15, 2014 11:42 AM
lafermedavid
17
May 11, 2013 06:55 PM
