Hi everyone. I'm trying to help a friend with his 89 Bronco II. His rear Driveshaft broke off and we're trying to put a new one on. The only problem is that we can't figure out EXACTLY how everything goes together. Can anyone post or e-mail me a picture of the assembly either from real life or a Chilton's. It would be much appreciated. Thanks
I agree with it being only four bolts, usually held in by red lock-tite so they might be a bit rough to remove. You might have to buy some multi-point sockets, usually you can break them free with a wrench using a cheater bar or tube. I usually replace those multi-point heads with regular (10.8 strength - about grade 5) metric bolts. I think they are 12 mm threads ...
If you have a choice, go to a junk yard and grab a regular UJ type shaft from a 84 or 85 Bronco, it should be a bolt up affair and much stronger than the narrowed down neck CVJ (Cardigan?) type affair on the later models. Or buy a brand new UJ type shaft for about $140-$180. James Duff carries those too.
