Replaced starter
Old Dec 4, 2014 | 11:11 AM
Furniture Doctor's Avatar
Furniture Doctor
Replaced starter
I replaced my starter on my '96 PSD yesterday. After replacing 2 batteries, glow plugs and wiring harness the truck was still hard to start in the colder weather. Fortunately my cousin let me use his heated garage. The top bold was a real pain in the ###. I loosened the 3 17mm bolts before I disconnected the wires. The large wire was also a tough one to remove. The little wire had to be cut and an eyelet was replaced. The little nut was completely rounded. The new starter spins really fast. I may try to see if it starts OK without the truck being plugged in. I used a reman starter from Advance since I needed to change it ASAP before the cold weather really sets in.
Old Dec 4, 2014 | 12:23 PM
cowmilker08's Avatar
cowmilker08
Did you verify that the GPR is functioning properly?
Old Dec 4, 2014 | 04:36 PM
Furniture Doctor
Starter
I did replace the GPR with one that I bought from Ford. Today when the temp was 25 the starter turned over quickly.
Old Dec 6, 2014 | 03:15 PM
ProjectDually's Avatar
ProjectDually
Are you using a de-gel fuel additive like Diesel 911?
Old Dec 7, 2014 | 09:37 PM
tshrager's Avatar
tshrager
Does it start properly with the new GPR?
mjtpolice76
May 15, 2009 09:57 AM
dyhrdford
Jan 20, 2008 10:33 PM
150blue
Feb 11, 2007 08:01 PM
yardboy
Dec 5, 2005 09:18 PM
bigsquirt
May 28, 2004 07:51 PM
