starter problem
Old May 14, 2009 | 07:35 PM
mjtpolice76's Avatar
mjtpolice76
starter problem
How do you know if your starter is going? truck is very hard to start has all it can do to turn over. Batteries are four months old and had them tested three weeks ago with a load tester and they tested fine. Changed the glow plug relay to a stancor two months ago and OHM's tested good on the glow plugs. Everythingis fine. How hard is a starter to change out. Disconnect the batts couple of bolts. anything I'm missing anything, any tips would be apperciated. does Napa have good starters?
Old May 14, 2009 | 07:45 PM
12ozd's Avatar
12ozd
Hard to start how? Turning over slowly?
If batts. are good,cables,terminals are good.Could be a starter.
Very easy to replace,you got it in your OP.
Napa starter should be fine (check on their warranty)
A HO diesel starter is worth a look.
Old May 14, 2009 | 08:00 PM
mjtpolice76
Very slow turning over sometimes it stops turning, turn the key and nothing.
Old May 14, 2009 | 08:08 PM
F350-6's Avatar
F350-6
Disconnect the batteries, couple of bolts on the starter, couple of nuts holding wires on the solenoid, couple of curse words balancing the starter while trying to get the wires back on the new solenoid, that's pretty much it.
Rebuilt items (starters, alternators, etc.) tend to fail much quicker than new stuff. If you go with NAPA, keep a copy of the receipt in the glove box. Some NAPA stores are corporate, some are independent. Their computers don't talk to each other, so if you want the warranty, you have to have the receipt.
Old May 14, 2009 | 08:09 PM
12ozd's Avatar
12ozd
There's not alot to the starting system.
If you are getting power to the starter solenoid (you are if the starter turns)
The batteries and cables are about it.
If the batteries are good,terminals tight and clean.
The starter is about all that is left.
The solenoid may be bad ( not allowing full amp/voltage)but not likely.
I would double check the cables/terminals/connections.
And the batteries. If all is good,pull the starter.
Not a hard job at all.
Hope this helps.Keep us posted.!!
Old May 14, 2009 | 08:39 PM
mjtpolice76
Thank you off to napa in the morning can't wait for a high torque one in the mail
Old May 15, 2009 | 09:04 AM
mjtpolice76
It was the starter that was causing the slow starts. Changed it out for a napa rebuild one for 205 dollars. There was already a rebuild in there. Truck fired up better than she has in the last year. Thanks for all the help.
Old May 15, 2009 | 09:32 AM
12ozd's Avatar
12ozd
You're welcome. Glad you got it fixed.
Old May 15, 2009 | 09:50 AM
preppypyro's Avatar
preppypyro
When I bought a starter I couldnt wait for a high torque one either, so I went to Napa here. I actually got a new "high torque" one from them, although I dont know exactly how high or torquey it is. It sure did work a world better then my old one. I keep the receipt in my glove box too
Old May 15, 2009 | 09:57 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Glad you got it fixed!
