rear axle swap
Old Dec 3, 2014 | 04:52 PM
dylansf23's Avatar
dylansf23
rear axle swap
What all years can we swap with?
My leave perches are 45" center to center.
my inner drum to inner drum is 55"
I ask because I want a heavier rear axle then my semi float Dana 60 with 3.55(have a front Dana 60 with 4.10 that will go in eventually)
I have a deal on a rear out of a 70's. Dana 60 full float and 4.10 gears for 300$
Old Dec 3, 2014 | 06:09 PM
f100beatertruck's Avatar
f100beatertruck
Generally 80-96/97 swaps. Around 83 the sterling 10.25 came out, before that it was the D60. There is a chassis cab axle that has more narrow spacing on the perches. Not sure if drive shafts or yolks changed though.
Old Dec 3, 2014 | 06:12 PM
dylansf23's Avatar
dylansf23
I know the sterling and I know the cab and chassis/dually have different perches.
I'm sure number dummy or on if the likes would have it. Or someone who also has an older truck
Old Dec 3, 2014 | 06:18 PM
dylansf23's Avatar
dylansf23
Double post
Old Dec 4, 2014 | 06:52 AM
fellro86's Avatar
fellro86
There are always things to consider with such swaps, such as u joints and brake lines. No parts book will ever tell you that, experience or trial and error tell you that. Parts books tell you what year the part was used in, nothing more.
I do believe I had looked up the u-joints and they were the same in the drive shaft, but the next thing is if the drive shaft length remained consistent.
Old Dec 4, 2014 | 06:01 PM
Franklin2's Avatar
Franklin2
Measure the 70's rearend. I have heard even though the front of the frame is more narrow and nothing swaps on the front, the rear frames are close to the same and the rears will swap.
70's trucks probably also had chassis cab rearends, so be careful there also. But all chassis/cab rearends were dually rears. So if wasn't a dually rearend you should be ok.
black & blue 78/9
Apr 6, 2018 03:48 PM
vento
1978 - 1996 Big Bronco
Jan 26, 2006 10:36 PM
Mdefoe
Oct 11, 2002 11:20 PM
