clutch noise
Old Jul 18, 2003 | 03:27 PM
travis c's Avatar
travis c
clutch noise
my clutch makes a clicking sound when pedal is fully released but when i barely push the pedal in (2mm or so) it goes away. is there an adjustment or is my clutch going out?
Old Jul 18, 2003 | 06:47 PM
travis c's Avatar
travis c
clutch noise
Old Jul 18, 2003 | 07:37 PM
mr clutch's Avatar
mr clutch
clutch noise
Travis
This could be a dirty input shaft or a problem with the slave cyl. Your rel brg is more than likely dragging on the diaphram on the pressure plate. Once you put pressure on the pedal it engages the rel brg stopping the noise. When you remove your foot from the pedal your rel brg is not fully disengaging the cover as a result of either the input shaft (clutch dust build up) or a fatigued slave cyl. I hope this helps.
Old Jul 18, 2003 | 10:20 PM
travis c's Avatar
travis c
clutch noise
rel brg? how would i adjust it to keep it from dragging??
Old Jul 19, 2003 | 02:15 AM
steve83's Avatar
steve83
clutch noise
Check the tiny plastic bushing on the lever that connects the pedal cross-shaft to the MC pushrod above the gas pedal.
Old Jul 19, 2003 | 09:43 AM
travis c's Avatar
travis c
clutch noise
is that located on the clutch housing?
Old Jul 19, 2003 | 02:27 PM
travis c's Avatar
travis c
clutch noise
oh nevermind, i didnt see the part that said above the gas pedal
Old Jul 21, 2003 | 06:59 PM
travis c's Avatar
travis c
clutch noise
bump
