AOD Question
Old Jul 18, 2003 | 01:38 PM
alcan60283's Avatar
alcan60283
AOD Question
i have a 1984 F-150 ranger w/ aod tranny and a 351W. PRoblem is, the shifts seem WAAAAY too long. 1st gear is like 0-40, and the engine is revving very high before it shifts. How can i adjust the shift points. Someone once told me there is a vacuum modulator on the side of the tranny, but i dont see it. Isnt there supposed to be a vacuum line going to the tranny? Because if there is, i dont see one going down there. Thanks for any help.
Old Jul 18, 2003 | 03:34 PM
rclarke's Avatar
rclarke
AOD Question
AOD has no vacumn modulator. You may have a problem with the throttle valve linkage. Make sure it's properly adjusted.
Old Jul 18, 2003 | 06:40 PM
Bubba Shrimp's Avatar
Bubba Shrimp
AOD Question
A word of caution: If the truck is driven with the cable unhooked or out of adjustment it can fry you transmission real quick.
Old Jul 18, 2003 | 08:31 PM
alcan60283's Avatar
alcan60283
AOD Question
ok, well, now that i know theres no vacuum modulator, how do i adjust the shift points? is there a computer on the 1984 trucks to adjust shift points? i need to know how to do this, otherwise, i am going to get a bellhousing adapter and bolt on a c6. But thats last resort. Please, anyone thats knows about the aod, any info on adjusting shift points is GREATLY apprecated.
John
Old Jul 18, 2003 | 09:04 PM
Bubba Shrimp
AOD Question
See if this helps. I still couldn't figure out how to do it, but maybe you can.
http://www.txchange.com/aodadj.htm
