Sponsored by: Real Truck
Blown Sparkplug!
Old Dec 17, 2014 | 08:38 PM
  #31
EXv10's Avatar
EXv10
Originally Posted by CuNmUdF250
It's never going away search or not......neither will 6.0 issues......20 years from now someone will post about a blown spark plug.....have to consider also ones mechanical ability or experience as well.....while you were able to make short work of a plug repair it's not for everyone myself included.....shame really that engines that might otherwise be considered bulletproof have such a issue as us spitting out spark plugs
That's what happens when one engineer says "we only need 3 threads in there" and everyone says; "you got it, you're the engineer". At least they caught it after a couple years.
Old Dec 17, 2014 | 09:29 PM
  #32
dlibson's Avatar
dlibson
Fix these all the time at the shop. I charge $200 if no coil $250 if coil needed. Honestly it takes about an hour, and costs about $50 in parts. Not sure how anyone gets more then that...
Check with the local parts stores and see if anyone rents the kits.
Old Dec 20, 2014 | 07:06 PM
  #33
starrider's Avatar
starrider
Originally Posted by Sand_Man
Got mine fixed for $192 plus another $50 for a coil from Rock Auto. My fault for not checking, since it developed what I thought was an exhaust leak months earlier. I checked the exhaust with it running, found nothing and just drove it. There were enough threads left in the head that I installed a new plug in the killed hole, drove it to the shop. Probably could've just left it like that, but I didn't. I'd like to know if anyone else with a blown plug had a similar warning, since I have trouble visioning a plug simply yanking threads and all in one fell swoop.
Yep, I had the same warning. Sounded like a small exhaust leak just tick tick tickin away. Now I realize that was the timer on the plug waiting to blow.
Just checked my warranty and it ran out 11/30/14 but I was also over on the miles by about 5000 so I guess it sucks to be me. Since this is a van I think I'll let the dealer take care of it.
Old Dec 23, 2014 | 09:20 AM
  #34
FordService's Avatar
FordService
Official Ford Rep
Originally Posted by starrider
...Since this is a van I think I'll let the dealer take care of it.
When are you heading in to the dealership, starrider? I'll be here if you need any help after your appointment.
Crystal
Old Dec 23, 2014 | 12:50 PM
  #35
EXv10's Avatar
EXv10
Like smelling salts, etc ?
Old Dec 24, 2014 | 08:41 PM
  #36
Cardinal Puller's Avatar
Cardinal Puller
I did all 10 with the Timesert kit. Bought it for $350, resold it for $300 plus $ 110 for the inserts. Didn't want to be on the road with a breakdown. Not hard, you do need some skills.
Old Dec 25, 2014 | 10:16 AM
  #37
vortec 1's Avatar
vortec 1
Working on cars and trucks my whole life and hearing drilling a head can be humbling and I have not had this happen and hopefully never will but check out this link, if you follow it exactly I dont see how you could mess it up and it cleared up the visual of what I visioned. My only concern is the life of the sleeve? Hope this helps some with this problem!!
Old Dec 26, 2014 | 12:18 AM
  #38
EXv10's Avatar
EXv10
[url m/watch?v=2opNGDKGdkQ"]+Ford spark plug thread repair kit+ TIME-SERT BLOWN OUT SPARK PLUG REPAIR blow out thread repair kit - YouTube[/url]
Wow that's pretty involved and I guess the second one would be easy but I would never do more than I had to. (one)
Old Dec 26, 2014 | 07:37 AM
  #39
projectSHO89's Avatar
projectSHO89
The sleeve will outlast the rest of the truck.
Old Dec 26, 2014 | 08:55 AM
  #40
vortec 1's Avatar
vortec 1
Thanks, Good to know!!! What are the best sleeves or most recomended brand out there?
Old Dec 26, 2014 | 01:31 PM
  #41
F250wilm's Avatar
F250wilm
hard fix
[QUOTE=oh2sd;14865215]Ok so here it goes, I am on my way to work today and POP! tsst, tsst, tsst. WTF is that, I stop and pop the hood and the noise is horrendous. Shut it down and a quick cell phone se
Go to Napa get the kit plus helicoil with copper insert he should take about 3 hours you should use a low torque drill with bottoming and pilot preferably tungsten or titanium bits they will lastlonger
Old Dec 26, 2014 | 08:02 PM
  #42
projectSHO89
Timesert, Cal-Van, and Lock-n-Stitch are all good. Helicoils and the Dorman kit are not.
Old Dec 26, 2014 | 10:09 PM
  #43
vortec 1's Avatar
vortec 1
They definetly look better than the Helicoils. Like I said this has not happened to my 5.4 but I will definetly file these just in case.Thanks
projectSHO89!!
Old Dec 27, 2014 | 01:41 PM
  #44
EXv10's Avatar
EXv10
Helicoils are for a static environment, not here.
Old Feb 17, 2015 | 12:45 PM
  #45
ALMACK's Avatar
ALMACK
Originally Posted by Gints
Its been talked to death - it is fords design fault (to few treads) in early aluminum engines. I had two blown plugs on 2001 f250 v10. To much torque -striped tread, to little - loose plug. And ticking noise is tale-tale sign (loose spark plug.... or manifold leak - bouth nasty to fix ). Heli coil is temporary fix in the long run. Buy the way, dealers have aluminum inserts, by mine experience they last longer, may be becose they made off the same material as head.
Anyone know what year that Ford made the switch to plugs with more threads on the V-10 ?
I had heard it was sometime in the 2003 model year.
