Electronic Brake Sensor Installation
Old Jul 18, 2003 | 11:24 AM
CalBob's Avatar
CalBob
Question Electronic Brake Sensor Installation
I have a 2001 F-150 SuperCrew with a tow package. I want to install an electronic brake sensor (I believe that is what they are called), so I can pull a trailer. Where can I find some instructions on how to hook up the brake sensor. Since I have a tow package I assume the wiring is under the dash already, correct? Thanks for any help or suggestions.
Old Jul 18, 2003 | 05:15 PM
rclarke's Avatar
rclarke
Your tow package should have included a packet with a small wire harness to hook up the brake controler. There should also be an instruction sheet that tells you where to plug it in. I believe the connector is on the right side of the steering column under the dash, you might have to search a bit for it, it may not be right out in plain view.
