help me decipher the codes
Old Mar 16, 2002 | 02:00 AM
PAUL_2's Avatar
PAUL_2
Old Apr 8, 2002 | 03:20 PM
wrenchinfool's Avatar
wrenchinfool
I checked my engine and I got a couple of stored codes. The first was code 42 (system rich) and code 34 (EVP Voltage above closed limit). I knew I was running rich but I don't know why. Does this other code have anything to do with my rich condition? Any help is appreciated.
JPF
1988 F350 4x4 351 efi
Old Apr 8, 2002 | 03:45 PM
mantta's Avatar
mantta
The EVP (EGR Valve Position) is a sensor mounted on the EGR valve that tells the ECM (computer) what position your EGR valve is in. It sounds like you have an EGR valve that is stuck.
Old Apr 8, 2002 | 07:33 PM
Phillip Guidry's Avatar
Phillip Guidry
If you did not have a lit up check engine light, erase the codes and recheck after a couple of trips....those codes could've been there for a while.
Phil
Old Apr 9, 2002 | 04:58 AM
wrenchinfool
My check engine light did come on and I also reset the codes before I tried them. A symtom it has is that it tends to miss at low acceleration when it warms up. I can goose it and it is fine.
JPF
Old Apr 9, 2004 | 01:03 PM
jefftbressler's Avatar
jefftbressler
just had problems with my O2 sensor...the check engine light never came on but i was running rich...ran the codes and got code 41 (running lean)...system was compesating by running rich...anyways it turned out to be a melted wire on the O2 sensor grounding out...a little electric tape did the trick...when i was troubleshooting i was told it was a waiste of time to run the codes if the check engine light wasn't on...this was untrue in my case...
Old Apr 10, 2004 | 06:51 AM
John B's Avatar
John B
Newbie question here....
How does one check codes on an 88 F150? Do i need a scanner or can it be done by cycling the ignition key? And this would be OBD1 correct?
Old Apr 10, 2004 | 07:33 AM
EPNCSU2006's Avatar
EPNCSU2006
It is OBD, yes, and you can check the codes yourself. Go to http://fordfuelinjection.com and click on "Getting Codes" to find out how it is done.
Old Apr 10, 2004 | 07:41 AM
John B's Avatar
John B
Thank You sir!
