Electrical problem
Old Nov 30, 2014 | 09:40 AM
JRS2's Avatar
JRS2
Electrical problem
Just fixed one thing, immediately have another problem ..... Anyways switched out a blower motor resistor, and it works fine. Problem now, truck won't start. It will crank, but I have no fuel pressure. Checked all the fuses, replaced one instrumentation fuse, no luck. Anyways another oddity I tried to check voltage at back of my fuses for 12 volt power, NONE of them have it. Is this odd, with key on ? When I put key in accessory position, nothing happens. So, wondering if I might have a Ignition switch problem ? Also I have a battery voltage meter on the dash, it is indicating only about 8 to 10 amps with key on before cranking, I usually don't look at it if truck cranks and runs, so not sure what is normal .....
Suggestions ??
Old Nov 30, 2014 | 09:42 AM
JRS2's Avatar
JRS2
In case my vehicle does not show, this is a 92 F150 5.0 4 WD. Has actually been a pretty reliable ride for the last couple of years .....
Old Nov 30, 2014 | 10:28 AM
rla2005's Avatar
rla2005
The Voltmeter will show the battery VOLTAGE with the key in the Start or Run position.
Old Nov 30, 2014 | 04:15 PM
JRS2's Avatar
JRS2
Ok, then, so how does one account for the battery voltage @ 8 or 10 amps at the meter on the dash, when in actuality it is approx 12 volts at the battery ? What would cause this oddity ?
Nobody has an opinion on the whole scenario as described ?
Old Nov 30, 2014 | 04:43 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
I think rla2005's point was the dash gauge reads in volts, not amps.
So, you have 12 volts at the battery. Check a few other points, maybe cigar lighter, headlights. Do you have a full 12V here? Verify that your dash gauge is reading correctly.
Check ground connections at the fender.
Old Nov 30, 2014 | 05:53 PM
rla2005's Avatar
rla2005
Inaccurate gauge, poor ground at G200 (behind passenger side kick panel), or poor power connection to the cluster. More than once I have found one of the connectors behind the cluster unlatched and slowly falling out of the socket.
Old Nov 30, 2014 | 09:43 PM
JRS2's Avatar
JRS2
Ok, thanks for the suggestions, if any others have them, feel free to chime in .... hope to look at those tomorrow ....
Curtis_v
16
Aug 6, 2017 02:25 PM
ZekeF3
1997 - 2003 F150
Aug 24, 2012 07:35 PM
sabresfan616
Aug 20, 2012 06:41 AM
paulm1
Electrical Systems/Wiring
Mar 1, 2004 10:01 AM
